Power in dc circuits supplying or consuming?
In DC circuits, resistors always consume power, while the behavior of capacitors and inductors can vary based on current direction. Voltage sources consume power when current flows into their positive terminal and exits the negative terminal, indicating they are sinking current. For current sources, if the calculated current direction opposes the given direction, it suggests an error in analysis. Using passive sign convention for resistors, inductors, and capacitors, and active sign convention for sources helps clarify power flow. Understanding these principles is essential for accurate circuit analysis.
spazzy32
hi guys! I've been having some trouble thinking about power in DC circuits. I've been guessing my way through my problems and have been correct most of the time, but i just wanted to know the following...
so if i have a dc circuit with a capacitor, resistor, inductor, and multiple voltage or current sources, how can i tell when each of the individual branches is supplying or consuming power? i know resistors always consume power, but I'm a little iffy on the inductors, capacitors, and sources. by default when i label my circuits, i use passive sign convention on the RLC (current goes from + voltage to - voltage) and i use active sign on the sources (i draw current from - voltage to + voltage).
thank you in advance!
Well, once you've completed your analysis with your given ASSUMPTIONS above, you look at the directions of the currents at each of the sources. If the current goes into the positive and exits the negative of a voltage supply, this means that the supply is sinking current and is consuming power. If, for a current supply / ammeter, the current that you calculated is going in the opposite direction of that given in the question... well, it probably means that you did your analysis incorrectly.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
