Neutral Wires: Potential and Safety
The neutral wire is typically at ground potential, but this can vary depending on the grounding point and the current flowing through it. Touching a neutral wire is not safe, as it may carry a return current that could create a potential difference. The grounding point may not align with the potential at the point of contact, posing a risk of electric shock. In AC circuits, understanding the positive and negative aspects is essential for proper analysis, especially if a DC offset is present. Therefore, caution is advised when dealing with neutral wires in electrical systems.
v_gurucharan
Is neutral wire at 0 potential??
Does that mean we can easily touch it??
Take a read through the following threads:
Neutral Wire:
https://www.physicsforums.com/showthread.php?t=221836
Simple Electrical Question:
https://www.physicsforums.com/showthread.php?t=251095
Neutral wire is usually at ground potential, but since the point at which your system is grounded (earthed) might have a different potential from the point at which you're standing, and since the neutral wire may be carrying a large return current (which means the point at which you're touching the wire may not be at Earth potential), you should refrain from needlessly touching the ground wire.
And yes, when analyzing AC circuits the + and - help facilitate your analysis. Unless there's a DC offset somewhere.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
