What is the speed of the stone just before it hits the ocean?
The discussion revolves around solving a physics problem involving a stone thrown horizontally from a cliff. The user successfully calculated the time of flight and initial speed but is struggling with determining the speed of the stone just before it hits the ocean. They initially proposed an equation for the final speed but received feedback indicating it was incorrect. Participants suggest re-evaluating the horizontal component of velocity just before impact to clarify the misunderstanding. The conversation emphasizes the importance of considering both vertical and horizontal motion in projectile motion problems.
DocDot
Im sorry I just realized this is in the wrong subforum...
Hello Everyone! I am new here and am having trouble with this webassign question. I was able to work out the answer to the first two but the last two are giving me trouble. I am not sure if this is right subforum to put this in, but I am in physics with calculus (Mechanics).
A boy throws a stone horizontally from the top of a cliff of height h toward the ocean below. The stone strikes the ocean at distance d from the base of the cliff. In terms of h, d, and g, find expressions for the following.
the time t at which the stone lands in the ocean
the initial speed of the stone
the speed of the stone immediately before it reaches the ocean
the direction of the stone's velocity immediately before it reaches the ocean
vf=vi+gt
xf=xi+vi(t)+(g/2)(t^2)
The answer I got for the first one was √(h/(g/2)) which was right
The second one I got was √((d^2)/(h/(g/2))) which was also right
For the third one I got vf=g(√(h/(g/2))) which I thought was right because vf for the x componet is 0 and the velocity is maximum at tf, however webassign is telling me I am wrong.
Thank you all for the help in advance!
If you show your steps leading to your result, the mistake can be better identified.
DocDot said:
...vf for the x component is 0 ...
Think about this a bit more...what is vf_x just before it hits the ocean?
