3 explanations of comet velocity. OK?
  • Thread starter Thread starter catkin
    Comet Velocity
Comets in eccentric orbits exhibit varying velocities due to the conservation of energy, angular momentum, and gravitational forces. As comets approach the Sun, their potential energy decreases, leading to an increase in kinetic energy and thus higher speeds. Angular momentum remains constant, with the moment of inertia being greatest when the comet is farthest from the Sun, resulting in lower angular velocity at that distance. Gravitational force provides centripetal acceleration, which is strongest near the Sun, further contributing to increased speed. The discussion emphasizes the complexity of applying circular motion concepts to elliptical orbits, highlighting the need for a deeper understanding of orbital mechanics.
catkin
[SOLVED] 3 explanations of comet velocity. OK?
This is from Advanced Physics by Adams and Allday, spread 3.31.
Explain why comets in very eccentric orbits move very slowly far from the Sun and very fast close to it. Give three explanations, one in terms of energy, one in terms of angular momentum, and one in terms of forces acting on the comet around its orbit.
Rotational kinetic energy: R.K.E. = 0.5 I {\omega}^{2}
Moment of inertia of point mass: I = m r^{2}
Angular momentum: L = I \omega
Centripetal acceleration: a = r {\omega}^{2}
Gravitational force: F = G m_1 m_2 / r^{2}
I would be confident this was right if I could understand and accept the implication.
In each case I answered the question by showing that r^{a} {\omega}^{b} is constant so \omega must become small as r becomes big and vice versa.
For energy, conservation of energy yields 0.5 m r^{2} {\omega}^{2} is constant so r^{2} {\omega}^{2} is constant.
For angular momentum, conservation of angular momentum yields m r^{2} {\omega} is constant so r^{2} \omega is constant.
For forces, centripetal acceleration and gravity yield G m_1 m_2 / r^{2} = m r {\omega}^{2} so r^3 {\omega}^{2} is constant.
Is it correct that r^{2} {\omega}^{2}, r^{2} {\omega}, and r^3 {\omega}^{2} are all constant? It feels unlikely -- very constrained. If it is true then what is its significance, physically? Am I being naieve -- are these simply properties of an ellipse?
Well it's clear what the significance is from the equations. You're saying their constant, so you're saying the things on the other side of the equal sign are constant. Are they? For the first two you assumed conservation of energy and momentum, which is correct, for the second, you have r^3w^2=masses and G, do the masses or the gravitational constant ever change? Nope
Hi catkin,
Let's see what the energy concept tells us. The total energy is constant and is the sum of the PE and KE. Now, the PE is low when near to the sun, being the least at the perihelion, and so the KE is high, and thus the speed is the high. (Why is the PE low close to the sun?)
Can you give similar qualitative arguments for the other cases?
Shooting star said:
Hi catkin,
Sorry for the delay -- other priorities. Here goes ...
PE is low(est) close to the sun because distance from Sun ("height") is smallest.
Angular momentum is constant. Moment of Inertia is greatest when furthest from the Sun and smallest when closest to the Sun, hence angular velocity is smallest when furthest from the Sun and greatest when closest to the Sun.
Gravity provides the centripetal acceleration and is greatest nearest the Sun, smallest furthest from the Sun but centripetal acceleration is proportional to the distance from the Sun hence the angular velocity is smallest when furthest from the Sun and greatest when closest to the Sun.
How's that? It hasn't yieded the Eureka moment yet, regards all 3 terms being constant.
Quite good reasoning. Let's add just a bit of math here.
Using the energy concept, the PE is -GMm/r. As r decreases, GMm/r increases, and so -GMm/r decreases.
Gravity does not provide the whole of the centripetal force, except in circular orbits. That is to say, the normal to the path of the comet is not directed toward the sun, except at the closest and the farthest points. But nearer to the sun, the centripetal force is almost in the direction toward the sun, and so mv^2/r is high, and r is low, implying v^2 is high.
But all the three "constants" you had mentioned cannot be constants. If they are, then both omega and r are constants, resulting in circular motion.
Thanks, Shooting Star, that makes perfect sense. For uniform circular motion any f(r,ω) will be constant because r and ω are constant.
The question is the second of a handful of four "practice questions" after a section on circular motion; we haven't covered elliptical orbits yet. Hence my attempt, using circular concepts to answer an elliptical problem.
Don't ask -- I don't understand why the authors ask a question beyond the topic. They often do it and it doesn't help when you're learning a new topic. Useful when it comes to synoptics and we're trying to pull it all together but not early on and definitely not as the second practice question!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
