Is My Kinematics Problem-Solving Approach Correct?
  • Thread starter Thread starter chrisfnet
    Kinematics
The discussion focuses on verifying the correctness of solutions to three kinematics problems involving projectile motion and tension in cables. The first problem involves calculating the time a ball hits the ground and its impact velocity after being fired from a height. The second problem requires determining the tension in two cables supporting a 28kg sign. The third problem addresses the acceleration of a system with two masses on an incline and the tension in the connecting string. Participants are encouraged to review the provided solutions and processes for accuracy.
chrisfnet
I was wondering, given my solutions and the problem statements; if someone could look over my work to see if there are any incorrect solutions/processes.
Thanks!
Problem 1
A ball is fired from a height of 3.0m above the ground, with a speed of 13m/s and an angle of 22 below horizontal. At what time does the ball hit the ground? What is the impact velocity?
Problem 2
A 28kg sign is suspended by two massless cables. Find the tension in each.
Problem 4
In the setup shown, m1 = 0.30kg, m2 = 0.45kg and theta = 11. Also, between the first block and incline, mu = 0.40. Assume the system moves so that the first block slides up the incline. What is the acceleration of the system? What is the tension in the string?
