(3 questions) Reflection and Refraction
The discussion revolves around solving problems related to light behavior in different mediums, specifically focusing on reflection and refraction. Participants are tasked with applying Snell's Law to determine angles of refraction for light entering and exiting water and glass prisms. There is confusion regarding the application of geometric principles and ray diagrams to visualize light paths. Key points include the importance of knowing the indices of refraction and the angles of incidence for accurate calculations. The conversation emphasizes the need for clear diagrams and understanding of the physics involved to solve the problems effectively.
whitehorsey
1. A light source, S, is located 2.0 m below the surface of a swimming
pool and 1.5 m from one edged of the pool. The pool is filled to the
top with water.
a) At what angle does the light reaching the edge of the pool leave the
water?
b) Does this cause the light viewed from this angle to appear deeper or
shallower than it actually is?
2. ni*sinΘi = nr*sinΘr
3. I have no idea how to do this problem.
1. A ray of light is incident upon a 600-600-600 glass prism, n=1.5.
the angle od incidence is 45 degree.
a) Using Snell's law, determine the angle Θr to the nearest degree.
b) Using elementary geometry, determine the values of angles A, B,
and C.
c) Determine angle of refraction.
the picture is an attachment
3. a. ni*sinΘi = nr*sinΘr
= sinΘr = nisinΘr/nr
= 1sin60/1.5
= 35.3 degrees
b./c. I have no clue. I know its suppose to be simple geometry but I can't seem to figure it out. :/
1. A sheet of plastic, n = 1.500, 25 mm thick is used in a bank teller's window. A ray of light strikes the sheet at an angle of 45 degrees. The ray leaves the sheet at 45 degrees but at a different location. Use a ray diagram to find the distance between the ray that leaves and the one that would have left in the plastic were not there.
3. How would you draw the ray diagram? I don't know if I need to use the 25 mm if so why and how?
Thank YOU! ;)
For 1 draw a picture and use your equation. It's just Snell's Law.
You know the angle from the bottom, the index of refraction of water (look it up if you don't) ... just solve for the angle at exit.
If you can't do that there's no point looking at the other questions.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
