30 kg boy in a 1000 kg elevator moving up 5 m/s
  • Thread starter Thread starter Nick63
    Elevator
A 30 kg boy in a 1000 kg elevator decelerates at -2.5 m/s² as it comes to a stop. The net force acting on the boy is calculated using the equation F = ma, resulting in a force of -75 N. The force of gravity acting on the boy is approximately 294 N, while the force exerted by the elevator on the boy is -369 N. The discussion clarifies the relationship between net force, mass, and acceleration, emphasizing that external forces can cancel each other out. Understanding these dynamics is crucial for solving the problem accurately.
Nick63
A 30kg boy is in a 1000kg elevator moving at +5m/s when it comes to a stop in 2 seconds. During the slow down...
1.what is the acceleration of the boy and the elevator?
2. what is the net force acting on the boy?
3.What is the force of the elevator on the boy?
Acceleration=Net force on object/mass
Force in Newtons=mass*acceleration
the boy and elevator have an acceleration of -2.5m/s^2
Okay. What about questions 2 & 3?
For #2 is the two forces on the boy Force of elevator on boy and Force of Earth on Boy(gravity)?
Yes.
PeroK said:
Yes.
I think I have the force of Earth on boy at 144 N and the force of the elevator at -2500N, is that right?
If that were true, the net force on the boy would be ##-2356N##, and hence the boy would accelerate at approximately ##-80m/s^2##.
Do you know the boy's acceleration?
I thought it was -2.5m/s^2
It is.
Do you know the boy's mass?
PeroK said:
It is.
Yes 30kg
So, you know the mass and the acceleration. What quantity are you trying to find? (For question 2.)
How are net force, mass and acceleration related?
so 30kg*(-9.8m/s^2+-2.5m/s^2)
That's not right. You may be confused by what net force means:
Suppose you were stuck in a room where the ceiling was pushing down on you and the floor was pushing up, so that you were getting squashed. In terms of kinematics (the study of motion) there is no net force on you. The two forces cancel out and you do not move. This situation is the same as if no forces were acting on you. That's the nature of forces and motion that you are currently studying. You might describe these as "external forces". There is no net external force in this case.
If you were studying internal stresses and strains on a body, then the two situations would be very different. But, this is not what you are looking for here. You're not measuring how much things are getting squashed, you're measuring how they are moving!
In any case, let me give you the key equation and explain it:
##F = ma##
##F## is the net external force on a body. If two external forces are in opposite directions, then their action tends to cancel out. If you push a body to the right with force ##F_1## and someone else pushes it to the left with force ##F_2##, then ##F = F_1 - F_2##. And, of course, if you both push with the same force ##F_1 = F_2##, then ##F = 0## and the body does not move. (You might be squashing it, but that's not what you're looking for here!)
##F = ma##
so then its just 30kg*-2.5m/s^2?
Yes.
