Torque-RequiredStair-Climbing Device
  • Thread starter Thread starter Saladsamurai
    Device
The discussion focuses on designing a motorized stair-climbing device for an ambulance gurney, intended to assist in moving heavier patients up and down stairs. The user seeks advice on calculating the necessary torque, estimating motor size, and identifying suitable portable power sources. They mention a target torque of approximately 4000 lb-in and inquire about the implications of motor specifications, such as armature and field voltage. Recommendations for motor sourcing include websites like globalspec.com, while considerations for battery sizing are suggested based on the height the gurney needs to be lifted. The conversation also raises concerns about the practicality of using such a device instead of elevators.
Saladsamurai
I am trying to figure out how to design a stair-climbing device similar to a hand-cart that climbs stairs.
I know that the loading will be ~500 lb.
It uses a 3-wheel climbing design design like http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200381541_200381541" except motorized.
I am trying to figure out how much torque I will need at the output of the gear box. I am assuming that this is simply a function of the distance from the climbing-wheel to the loading.
I also would like to figure out what size motor would work in that it should be relatively small and run off of a reasonably small portable power source.
I have no real design experience, so I was hoping for some input/advice.
What kind of small portable motors are out there and where can I see their specs?
What kind of power sources are out there?If my questions are not that clear, let me know and I will try to elaborate.
Thanks,
Casey
EDIT to help put this into better perspective, the motor is to power a 3-wheeled design like the one shown above, but it is to be used on an Ambulance Gurney (stretcher) to assist in moving 'larger' people up and down stairs.
Anyone know of any good sites for motors of this sort? Google is ok, but I would like some recommended sites.
Searching "motors" is a little painstaking.
EDIT: Ok, I am http://www.baldor.com/products/product.asp?1=1&page=1&orderBy=HpDecimal&product=DC+Motors&family=General+Purpose|vw_DCMotors_GeneralPurpose" right now.
Can someone explain what armature vs field voltage? Do I need to consider these?
I googled around and found that armature voltage is the occurs on the coils, but I am not sure why I need to know this :redface:
Any thoughts on motors/power sources? I am looking at something like http://www.baldor.com/products/deta...l+Purpose|vw_DCMotors_GeneralPurpose&hp=2.00", but I am not sure if there is a lightweight portable rechargeable power source to go with.
I figured that the torque I need to deliver is ~4000 lb-in
Can I go with a smaller motor without getting to crazy with the gear box? Is 2 HP at 2500 rpm considered a "big" motor.
I know this is a broad question that is design particular, but I am in need of some help/advice as a strarting point/
Thanks
You'll be able to find a motor that fits your specifications on www.globalspec.com.
As for size of the motor and how much power will be required, I would look into how high you're looking to lift the patient/gurney. By doing this, you can calculate the required potential energy change which can give you an idea on battery sizing.
Also I have to ask- why the heck would you want to carry a patient up stairs on a gurney? What about elevators?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
