Designing an inline flare gas combustion chamber
The discussion centers on designing an enclosed flare gas combustion chamber for a biomass gasifier that produces 700,000 BTUs of heat per hour. The user is facing challenges with maintaining the flame within the burn chamber when exhaust is directed through pipes to heat exchangers. Suggestions include adjusting the size of the burn chamber and inlet pipe to control gas velocity and pressure, which may help keep the flame contained. Reference to ANSI/API Standard 521 is made, highlighting its relevance to flare stack design in similar applications. The user is seeking solutions to ensure the flame remains stable within the chamber.
benjaminb
I have built a nice biomass gasifier that produces about 700,000 btu's of heat per hour by burning or flaring the gas that comes out of it.
What I want to do is, to flare the gas in an enclosed chamber so I would be able to capture all the exhaust and run it through some heat exchangers for heating hot water.
I have a suction fan that pulls the gas out of the gasifier and then blows it into the flare/burn chamber and through the heat exchangers.
In order to save using another blower to blow air, (oxygen) into the flare/burn chamber, I meter it in on the suction side of the blower where it is mixed to the correct fuel air mixture.
This works great burning the gas in the flare/burn chamber into the open atmosphere. But when I put a lid on the chamber and force the exhaust to flow through pipes to the heat exchangers, then the flare doesn't want to stay in the burn chamber. It either jumps down the pipe through the blower right to where the oxygen inlet is, or it travels up the pipes from the burn chamber towards the heat exchangers.
I would like to figure out how to get the flame to stay in the burn chamber.
Does the burn chamber need to be larger?
Does the inlet pipe need to be smaller so the gas is traveling to fast for the flame to jump down the pipe to the oxygen inlet?
What does the pressures and velocities have to do with where the flame stays?
If anyone has any ideas, I'm all ears!
If memory serves me correctly, you should be able to find some information in ANSI/API Standard 521, "Pressure-relieving and Depressurizing Systems".
That standard has a lot of information on flare stacks used in the offshore oil and gas business which sounds similar to what you are working on.
CS
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
