Change in entropy at constant temperature
The discussion focuses on calculating the entropy change of a perfect gas compressed at constant temperature. The user seeks assistance with determining the heat transfer (Q) necessary for the calculation. Key equations mentioned include the first law of thermodynamics and the work done during isothermal expansion. The contributors clarify that since temperature is constant, there is no change in internal energy, leading to the conclusion that Q equals negative work (Q = -W). Ultimately, the user confirms their understanding and correctness of the solution with the help of the forum members.
ricof
Calculate the entropy change when 0.011m3 of a perfect gas at a constant temperature of 273K is compressed from an initial pressure 1x10^5 N/m/m to a pressure of 1x10^6 N/m/m.
I know the equation but cannot work out Q! Please help!
dS=Q/T
Hi ricof, welcome to PF. Can you combine the First Law with what you know about the energy of an ideal gas at constant temperature?
Some more relevant equations.
The first law
\Delta E=Q+W
Work for isothermal expansion
W=-nRTln\frac{V_{f}}{V_{i}}
If you combine this with what you know about change in internal energy at constant temperature, like Mapes said, and that integral of yours, you can figure out the answer.
Because T is constant, there is no change in internal energy right?
And also, in the above equation for isothermal expansion, how is n calculated?
Agreed on the first question. For the second: apply the ideal gas law.
Ok, so as dE = 0,
Q = -W
and as PV = nRT,
-W=PV ln (v1/v2) which is Q
Thanks guys, my answer is correct. Thanks for helping!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
