Help in need : Rational functions problem
The discussion revolves around comparing two rational functions that model fish populations in a lake: f(t) = 40t/(t^2+1) and g(t) = 45t/(t^2+8t+7). The goal is to determine where g(t) is greater than f(t). The user attempts to solve the inequality by finding a common denominator and simplifying the expression, ultimately leading to a cubic polynomial. They express uncertainty about the next steps and suggest finding the intersection points of the two functions as a potential method for comparison. The conversation emphasizes the need for further calculations to identify the intervals where g(t) exceeds f(t).
BuffaloSoulja
A scientist predicted that the population of fish in a lake could be modeled by the function f(t)= 40t/(t^2+1), where t is given in days. The function that actually models the fish population is g(t)=45t/(t^2+8t+7). Determine where g(t)>f(t).
f(t)= 40t/(t^2+1)
g(t)=45t/(t^2+8t+7)
g(t)>f(t)
g(t)>f(t)
45t/(t^2+8t+7)>40t/(t^2+1)
45t/(t+1)(t+7)-40t/(t^2+1)>0
Find LCD by multiplying 1
45t/(t+1)(t+7) x (t^2+1)/(t^2+1)-40t/(t^2+1) x (t+7)(t+1)/(t+7)(t+1) > 0
Simplifies to
(5t^3-320t^2-235t)/(t+1)(t+7)(t^2+1)
5t(t^2-64t-47)/(t+1)(t+7)(t^2+1) >0
Am i doing this correct? I don't know what to do next.
Another way of doing it is to find where f(t) and g(t) intersect and then evaluate the equations at values a little bit off those intersection points to find which one is higher
So i suggest you solve:
\frac{40t}{(t^2+1)} = \frac{45t}{(t^2+8t+7)}
Step one should be multiplying both sides by (t^2+8t+7) and (t^2+1)
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
