Pressure/Surface Area. Need to Find SA and Calc. Pressure.
  • Thread starter Thread starter jefgreen
    Area Pressure
jefgreen
... Answer Found
bump. The reason I have no attempt at the solution is because my instructor never covered anything regarding surface area...
Bump. Help please.
