Lead/Lag compensator - lead and lag time to pole and zero locations
The discussion centers on converting pole and zero locations of a lead-lag compensator into lead and lag time, and vice versa. The original poster has a digital compensator requiring gain, lead time, and lag time, but only has the poles and zeros. A response suggests using a Bode Plot to analyze gain and phase margin, noting that poles contribute to lead and zeros to lag. However, the original poster emphasizes their need for time-domain specifications and expresses confusion about deriving lead and lag time from the transfer function or Bode plot. The conversation highlights the challenge of translating between frequency and time domain representations in control theory.
adamkse
Hi,
I am having difficulty understanding how to convert pole and zero locations of a lead lag compensator into lead and lag time and vise versa.
I have a digital lead and lag compensator which requests: gain, lead time (min) and lag time (min). However i have the gain zeros and poles of the compensator.
If someone can tell me how to do this i would be most grateful.
Adam
adamkse said:
Hi,
Adam
Given the DC gain and poles and zeros of the transfer function, you should be able to make a Bode Plot that will show you your gain and phase margin. A pole gives you lead, and a zero gives you lag. You can adjust the position of the poles and zeros to ensure that you have adequate phase margin to ensure stability.
http://en.wikipedia.org/wiki/Bode_plot
Although I notice that the concept of lead-lag compensation may be treated a bit differently in control theory, compared to the circuit design context that I'm familiar with:
http://en.wikipedia.org/wiki/Lead-lag_compensator
Hope that helps.
yes i know that you can draw a bode plot from it to get the phase and gain margins but my specs are in the time domain so I have it in transfer function form like K.(s+zd)(s+zg)/(s+pd)(s+pg) where d is for lead and g is for lag. I don't understand how I can get this lag or lead time from either the bode plot or the root locus.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
