3D Engineering Software & Classes: What to Try
In summary, the software you recommend to try to learn about 3d engineering is Pro-Engineer, Solid Works, and Solid Edge. If you're a student, whatever is available at your computer labs should probably be what you learn. The industry standard for mechanical engineering is Pro-E. Pro-E is a pain to learn, but their latest edition: "Wildfire" is getting better. Catia is another high-end package used almost exclusively in Aerospace and Automobile applications. I think Boeing and GM use this software. It looks incredibly powerful, but the ticket price is enough to make any small company blush, let alone a student. If you have to buy something yourself, and a student version of a real solid modeling
Euphoriet
105
What software do you recommend to try to learn.. maybe take some classes related to 3d engineering.. not just mechanical but also structural.. etc
What are you planning on doing with it, specifically?
Are you student or professional?
I've used several packages, and seen demos of several others. "Best" is relative.
I am still a student.. i tried desktop pro but now its not really something I can use... what are some of the things I should be looking out for?
Well, if you're a student, then whatever is available at your computer labs should probably be what you learn. :tongue2:
The industry standard for mechanical engineering is Pro-Engineer. In my opinion, it isn't very user friendly, and is a bit of a pain to learn, although their latest edition: "Wildfire" is getting better.
Pro-E has the ability to do finite element modeling through Pro-Mechanica which is an add-on.
Solid Works and Solid Edge are two middle-of-the-road packages. I haven't used them personally, but from the demos I've seen they seem to be much easier to learn, but may not be as powerful as Pro-E.
I'm not sure what they use in typical structural engineering firms.
If you have to buy something yourself, and a student version of a real solid modeling package isn't available to you, you could always give AutoCAD a run around the block. It's got solids capabilities which would let you learn how to build objects in 3D. The real drawback is that plain-old autoCAD isn't parametric, meaning once the object is designed, you can't go back to modify any values. On the other hand, AutoCAD is the industry standard for 2D drawings, and definitely is much better than any 3d package for architectural type work or space planning.
I have never heard of Catia... I have seen people use Pro-E and I believe my school has an old version of Solid Edge. We also have softimage but heh that's a whole different thing.
Go for Pro-E then. Wildfire if you've got a choice.
Hit the library or bookstore and pick up a $20-30 tutorial book. The stuff I've found when doing internet searches is either garbage or geared toward those with some experience. Even better, ask your friends to see if anyone's got rudimentary knowledge and is willing to teach you. It's a bear to learn in a vacuum.
Ok man thanks, I might not be able to get my hands on Pro-E but I'll keep an eye on it and do whatever I can to try to learn the program.
Oh... I thought that the school had it available when you said that you saw people using it.
Learn what's available. Pro-E would probably be better to know in the long run, but the main thing to learn (which any package can teach you) is how to visualize an object and how to figure out how to build it up in virtual space.
Another package which has a large following at my school is I-DEAS. I'm not a big fan, myself... the final results look too cartoony to me (their color scheme really stinks... oranges and pinks). There's almost no comparison to some of the stuff my senior design team turned out in Pro-E. I'm probably judging a book by its cover though.
Alright. Enough from me. I'll get off my soapbox and let someone else get their $.02 in.
How's this, attend a seminar on how to use the product and get a 90-day trial of the software on CD. Probably a big sales pitch too, but it is free! :-)
http://www.solidworks.com/pages/news/listseminars.html
I used CADKEY when I was in school, and played around with AutoCAD, both retail for around $3500 now (back then the retail was lower and the student edition was like $150, might want to check it out). SolidEdge and Esprit seem to go for around the $5k mark depending on what options you want, still pricey stuff and each have their pros/cons. I actually liked CADKEY on DOS, your hands barely left the keyboard and it seemed much faster that way.
As an alternative with a very easy to use interface of a nearly CAD-level program, Rhino is something to consider and the $900 retail and $200 student price are quite attractive. Free trial download is good for 25 saves.
http://www.rhino3d.com/
Also, a year or so ago a free version of Pro-E called ProDesktop was available but discontinued. Not sure what the pricing is, but may be another option for you to investigate.
http://ptc.com/appserver/it/icm/cda/icm01_list.jsp?group=201&num=1&show=y&keyword=355
Cliff
Thanks for those links.. I checked out ProDesktop before unfortunatly I had to reinstall and my old key doesn't work anymore.
So all this programs are not meant to be used for just modeling mechanical stuff but also structures of buildings and such things?
Hrmm... probably not so much.
You know, you may get a decent response calling a few structural engineering firms, telling them you're a student, and asking what they'd recommend you learn.
Either that, or wait and see if any structural engineers pop up here...
my prof says catia is overpriced and not worth it
he says solidworks can do what catia does & solidworks has nice relations with the academic community
I'm not really sure what exactly your looking for, and I can almost promise you this program will not be used in any school, but it is still a sweet program, and last I checked, free.
http://zmodeler.nfscheats.com/
It has been used in the gaming community for years to make car models (and more) for games like need for speed, 4x4 evo 1 and 2 and many others. The last version I used was pretty buggy but from the quick glimpse I gave the site, it seems to have improved a good deal.
Also, if you can use linux it has a few GNU 3d modelling programs as well. Again, not industry standard, but free and something that can atleast get you in the swing. My brother learned with zmodeler, and can apply almost everything he learned to using cad or a few other programs he uses (which are industry standards, I just don't remember them)
Books about 3D- Modelling can be found at http://megabytebooks.com/catalogue/324/
1. What is 3D engineering software?
3D engineering software is a computer program that allows engineers and designers to create, modify, and analyze 3D models of objects or systems. It is commonly used in fields such as mechanical engineering, architecture, and product design.
2. What are the benefits of using 3D engineering software?
3D engineering software has several benefits, including increased efficiency and accuracy in design, the ability to visualize and test designs before production, and the ability to easily make modifications and iterations. It also allows for easier collaboration between team members and can reduce the time and cost of prototyping.
3. What are some popular 3D engineering software programs?
Some popular 3D engineering software programs include AutoCAD, SolidWorks, CATIA, Inventor, and Fusion 360. These programs vary in their features and capabilities, so it is important to research and determine which one best fits your needs.
4. What should I look for in a 3D engineering software class?
When looking for a 3D engineering software class, it is important to consider the instructor's qualifications and teaching style, the course curriculum and topics covered, the level of hands-on practice and projects, and the software and technology used in the class. It can also be helpful to read reviews or ask for recommendations from others who have taken the class.
5. Can I learn 3D engineering software on my own?
While it is possible to learn 3D engineering software on your own through online tutorials and resources, taking a class or workshop can greatly improve your skills and understanding of the software. In a structured class setting, you can receive guidance and feedback from an experienced instructor, as well as have the opportunity to practice and collaborate with others.
  • Astronomy and Astrophysics
  • STEM Academic Advising
  • Atomic and Condensed Matter
  • DIY Projects
  • New Member Introductions
  • General Engineering
