3x230V grids without neutral -- What countries use it?
  • Thread starter Thread starter Merlion
    Neutral
The discussion centers around the existence and characteristics of 3x230V electrical grids without a neutral wire, specifically inquiring about which countries utilize this system. Participants explore the implications of such configurations, including safety concerns and grounding practices, while referencing specific countries like France, Belgium, and Norway.
  • Some participants identify France, Belgium, and Norway as countries with 3x230V grids without neutral.
  • One participant notes that Norway is transitioning to a 4-lead distribution system, also known as 400V distribution.
  • Concerns are raised about the safety of floating lines in a delta configuration, suggesting potential dangers from capacitive or inductive coupling.
  • Participants discuss the grounding practices in Norway, indicating that the center of the delta may be grounded at the local transformer, but individual houses must provide their own safety ground connection.
  • There is a distinction made between Ground Fault Interrupters (GFCIs) and Residual Current Devices (RCDs), with some participants arguing about their functionalities and implications for safety.
  • One participant mentions that Finland may be another location where this system is used, particularly in hospitals.
Participants express differing views on the safety and functionality of 3x230V grids without neutral, particularly regarding grounding practices and the effectiveness of GFCIs versus RCDs. There is no clear consensus on the implications of these configurations.
Participants highlight the importance of grounding and the potential risks associated with floating lines. The discussion includes technical details about delta and wye configurations, but some assumptions and definitions remain unresolved.
Merlion
Does anybody here happen to know which countries have 3x230V grids without neutral. I know that this exists in some areas in France and Belgium. Was told Norway as well, not sure? Any other?
Thanks
Try a google search for:
3 phase supply voltage by country
Norway is correct, but the power companies are starting to introduce 4-lead distribution, also called 400V distribution (the classic 3x230V is a delta connection, the 4-lead is a star distribution).
Svein said:
(the classic 3x230V is a delta connection).
I presume you have RCDs in Norway. Does that mean that 1 leg is connected to ground?
No. Check out https://en.wikipedia.org/wiki/Three-phase_electric_power. The article contains a drawing:
And a short notice: "There are two basic three-phase configurations: wye (Y) and delta (Δ). As shown in the diagram, a delta configuration requires only 3 wires for transmission but a wye (star) configuration may utilise a fourth wire. The fourth wire, if present, is provided as a neutral and is normally grounded. The "3-wire" and "4-wire" designations do not count the ground wire used above many transmission lines, which is solely for fault protection and does not carry current under non-fault conditions."
That surprises me. Seems extremely dangerous to me as these lines float with respect to ground, meaning they can be at any potential including a leak, capacitive or inductive coupling from a 10kV primary for example. Furthermore RCDs are no longer functional in such configuration.
  1. The center of the delta is grounded at the local supply transformer (5kV-230V).
  2. Every house must provide a local safety ground connection. It is not connected to any of the supply wires.
  3. Both wires are considered "live".
  4. I do not know exactly what an RCD does, but from about the year 2000, every fuse in the fuse cabinet must include a Ground Fault Interrupter circuit. A GFCI works by measuring the current leaving one side of a power source (the so-called "live" or "hot wire"), and comparing it to current returning on the other (the "neutral" side). (cited from https://simple.wikipedia.org/wiki/GFCI). Thus, the potential on the wires relative to ground is completely irrelevant.
There's some "inconsistencies" here.
1. Delta windings don't have a center, that's the nature of the problem
2. That's the case in most parts of the world but has only meaning if the supply side is grounded as well. A return path via the Earth must exist for earthing to be functional
3. Understandably
4. Aaah, you make use of a GFCI. Difference with a RCD is that the latter trips in case of a ground failure. A GFCI only tells you the problem is there. Someone has to come and fix it ASAP. It's called an IT-system. That also means that high impedance grounding must exist at the supply side either via one leg of the transformer or an artificial neutral point.
Interesting to know. Finland is probably is probably the only part of the world where this is used in the public sphere other than hospitals. Got to visit that place :-)
Yes, but the supply transformers do not have to be in a delta configuration in order to supply three-phase delta. They may just as well be in a wye configuration and then it is easy to ground the center.
Well, it trips when the imbalance is >15mA (or 10mA, I do not recollect).
11K
  • · Replies 32 ·
  • · Replies 46 ·
  • · Replies 78 ·
19K
18K
