What is the Max Load Capacity for a 6x6 Lumber Post in Canada?
  • Thread starter Thread starter blimkie.k
    Load Max
The maximum load capacity for a 12-foot tall 6x6 wooden post in Canada varies significantly based on the type and grade of timber used, with compressive strengths ranging from 960 to 1700 psi for different species. For a general estimate, a safe maximum design load is around 12,000 lbs, assuming a conservative allowable stress of 400 psi. It's important to consider the need for stabilization if the post exceeds 20 feet to prevent bending moments. Resources like the COFI website may provide useful information, but specific load charts for Canadian lumber standards can be challenging to find without purchasing additional texts. Understanding the specific timber choice and applying appropriate safety factors are crucial for accurate load calculations.
blimkie.k
This should be a pretty simple but I am having trouble finding the right information.
For a 6x6 wooden post for now well say 12' above the footing I need to determine the max load vertical load it can take before it fails. I live in Canada so was looking around Canadian lumber standards and stuff like that for span and load charts but can't seem to find them. I'm hoping an engineer can't link me to something.
I have a Canadian handbook of steel construction which provides everything fro steel so I need something like that but I don't want to go out and buy another 150 dollar textbook.
And no its not for school or work related its a personal project I am going to be doing on property my mother owns.
These people are on your doorstep.
All civil engineers should know of COFI
http://www.cofi.org/
I have some american standards tables, but properties vary widely depending upon the grade and type of timber:
Southern cypress, douglas fir,eastern hemlock,southern pine,redwood,eastern spruce.
American dressed lumber actual size is 5.5 x5.5 section properties available, max tensile stress, max horiz shear, max compressive stress, youngs modulus - if we can narrow the timber choice down a bit, or send me a PM with an email address so I can scan the table to it.
The compressive strength of (wet to dry)
Douglas Fir is 1300 - 1700 psi
Hemlock, Western is 1300 - 1650 psi
Pine, Eastern white is 960 - 1200 psi
note: if the 6x6 is more than 20 feet stabilizing becomes necessary to avoid bending moments.
Are you planning to apply your own safety factor or are you really looking for the maximum allowable load capacity? The capacity of a 12' tall 6x6 post varies greatly as described above. For maximum design load you should be safe using 400 psi, that's about 12,000 lbs. But you need to add up the loads based on values that go with your allowable stress. S
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
