Writing A Trig Expression as an Algebraic Expression
The discussion focuses on rewriting the trigonometric expression cos(2arccos 2x) as an algebraic expression. Participants clarify that by letting u = arccos(2x), the expression simplifies to cos(2u). They utilize the double angle formula, cos(2u) = 2cos²(u) - 1, leading to the final result of 8x² - 1. The initial confusion about the presence of the '2' in front of arccos is resolved through this simplification process. Ultimately, the correct algebraic expression is confirmed as 8x² - 1.
themadhatter1
Write the Trigonometric Expression as an algebraic expression.
cos(2arccos 2x)
Probably the inverse properties, I'm not sure.
I know I can rewrite this equation as.
u= arccos 2x
cos(2cos u=2x)
I can also say that the adjacent leg is 2x units long and the hypotenuse is 1 unit long. Then using the pythagorean theorm I can figure the opposite leg to be sqrt(1-4x2)
I'm not sure If this is necessary though can someone point me in the right direction? The 2 in front of the arccos is throwing me off because if that wasn't there I would just use the inverse property and cos(arccos 2x) would equal 2x.
If u=cos-1(2x) then you want to find cos(2u).
cos(2u)=cos2u-sin2u=2cos2u-1 = 1-2sin2u
and cos2u = (cosu)2
I'm not sure I understand why you'd want to find cos(2u)
The answer is supposed to be 8x2-1 and that's the answer listed in the back of the book.
cos(2cos-1(2x))
if you put u = cos-1(2x), wouldn't cos(2cos-1(2x)) become cos(2u)?
Thanks, now I understand.
Once you have simplified it to 2cos2u-1 all you have to do is simplify it with the u in place
cos2(arcsin 2x)=2x
2(2x)2-1
8x2-1
Thanks!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
