What is the Probability Distribution Function for Total Rotten Fruit?
  • Thread starter Thread starter ouiouiwewe
    Product
The discussion focuses on deriving the probability distribution function (pdf) for the total number of rotten fruits, combining apples and oranges with respective probabilities of rotting. The initial approach suggests that the pdf resembles a product of two binomial distributions, but the need to sum over all combinations complicates the expectation calculation. The expectation is intuitively calculated as x*pa + y*po, which aligns with manual tests. Various formulations of the probability of z rotten fruits are presented, ultimately leading to a simplified expression using binomial coefficients. The conclusion emphasizes the connection between the derived pdf and the binomial theorem.
ouiouiwewe
Hi guys,
Here's a description of the problem:
Suppose we have x apples and y oranges where each apple has a probability pa to rot and each orange has a probability po to rot, then what's the pdf of the total number of fruit z being rotten.
This pdf looks like a product of two binomial distributions on the surface. However, since z = x+y, x >= 0, y >= 0, then it is actually necessary to sum over all combinations of scenarios (i.e. 6 fruit rotten = 3 apples rotten + 3 oranges rotten or 6 fruits rotten = 1 apple rotten + 5 oranges rotten).
By intuition, I worked out the expectation to be x*pa + y *po and it appears to be correct when I manually tested my problem on a spreadsheet. However, I am not quite sure how that expectation can be derived from this messy pdf.
Any suggestions?
Thanks.
Mathematics news on Phys.org
The probability that z fruits will rot, is P(A)^0·P(O)^z+P(A)^1·P(O)^(z-1)+P(A)^2·P(O)^(z-2)+...+P(A)^z·P(O)^0
You could also write that as:
\sum^{z}_{k=0}P(A)^kP(O)^{z-k}
This is close to the derivation I had, but instead of P(A)^[something] and P(O)^[something], I had two different binomial distributions. I have no problem getting the pdf, but I have trouble simplifying the expectation.
Are you familiar with this division?
(a^n-b^n):(a-b)=a^{n-1}+a^{n-2}b+a^{n-3}b^2+\ldots+b^{n-1}
I saw this sum in the derivation of the binomial expectation. Anyhow, this is what I have for the probability of having 2 rotten fruits:
prob of having 2 rotten apples * prob of having 0 rotten oranges
prob of having 1 rotten apple * prob of having 1 rotten orange
prob of having 0 rotten apples * prob of having 2 rotten oranges
This seems to be the product of two binomial distributions and then summed over all possible combinations.
(Ignore my first post, there are errors in it.)
Let's say you have 2 fruits. Then:
-Both fruits can be apples. The probability for those being rotten is P(A)2
-Fruit 1 can be apple, fruit 2 can be orange. The probability for those being rotten is P(A)·P(O)
-Fruit 1 can be orange, fruit 2 can be apple. The probability for those being rotten is P(A)·P(O)
-Both fruits can be oranges. The probability for those being rotten is P(O)2
Since we don't know how many fruits we have, the probability that both the fruits will rot, is the average of the probabilities above, which is:
(P(A)2+2 P(A)·P(O)+P(O)2)/4
The probability that z fruits will be rotten is:
\frac{\binom{z}{0}P(A)^zP(O)^0+\binom{z}{1}P(A)^{z-1}P(O)^1+\binom{z}{2}P(A)^{z-2}P(O)^2+\ldots+\binom{z}{z}P(A)^0P(O)^z}{2^z}
This is exactly the same, but said in a shorter way:
\frac{\sum^{z}_{k=0}\binom{z}{k}P(A)^{z-k}P(O)^k}{2^z}
By using this equation: (a+b)^n=\binom{n}{0}a^nb^0+\binom{n}{1}a^{n-1}b^1+\binom{n}{2}a^{n-2}b^2+\ldots+\binom{n}{n}a^0b^n
We get that:
\frac{\sum^{z}_{k=0}\binom{z}{k}P(A)^{z-k}P(O)^k}{2^z}=\frac{(P(A)+P(O))^z}{2^z}=\left(\frac{P(A)+P(O)}{2}\right)^z
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
