5 watt radial turbine design - I need conceptual help
The discussion centers on designing a radial turbine capable of delivering 5 watts from compressed air at high RPMs, with a target efficiency of 30%. The user, Mike, seeks guidance on the design process, particularly for manufacturing in a harsh electromagnetic environment, and is exploring cost-effective solutions. Suggestions include considering 2D turbine designs for easier machining and the possibility of chemically etching stainless steel for turbine fabrication. There is also a focus on the challenges of sourcing affordable micro turbines and the importance of managing bearings and vibration for durability. The conversation highlights the complexities of turbine design and the need for practical, low-cost manufacturing methods.
Mike_In_Plano
I'm looking to design a radial turbine to deliver 5 watts from compressed air (60-90psi) at 20,000 to 40,000 RPM. 30% efficiency would be suitable.
I reviewed related patents-got little from them. I also reviewed my college textbooks, but they address incompressible, momentum transfer problems.
Any suggestions on how to approach this sort of problem?
Mike
I could probably help. Still need help?
Yes, thank you, APC.
This is an old thread, and I had almost given up hope. I welcome your input.
- Mike
Were you looking to just design one for the sake of it, or designing one to actually manufacture?
I ask because that will probably determine whether you should go with a 2D or 3D turbine. Google mit micro turbine for an example of a 2D turbine.
Let me know, I have written code and could easily just give you the necessary dimensions necessary.
Thanks APC,
My need is for a turbine / generator to function as part of a system that operates in a harsh electromagnetic environment. My rational is that the power could be supplied via the house compressed air, doing away with the need for electrical interconnects.
I've intended to move the product into low volume production (100-200/yr) and it would be great if I could find a turbine on the shelf for 250-$350, but the best I've found was more than $1K. At this point, I'm not certain whether such cost targets could be met.
As far as the geometry, it would be great to have something easy to machine and assemble. My favorite machine shop doesn't have 5 axis equipment. As to balancing, I could probably build a fixture to strobe it - if needed
I can't express just how appreciative I am that you've taken an interest in this work. It's frustrating to have proceeded so far and be forced to stop over just one item...
Best Wishes,
- Mike
I'm not familiar with where you can purchase your own micro turbines. You would probably have to make them yourself for the time being.
A cheap low quality solution is to chemically etch stainless steel.
http://www.micromark.com/MICRO-MARK-PRO-ETCH-PHOTO-ETCH-SYSTEM,8346.html
to get 2D turbines that look like this
http://www.fas.org/man/dod-101/army/docs/astmp98/figv10.gif
Also, 5 watts is an absurdly small amount of power. Make the turbines is very cheap in this way, but the generators are always the expensive part.
We've used DC brushless motors before that run in reverse from companies such as Faulhaber and Maxon Motor. Although getting appropriate bearings and the shaft link is not as easy as you would think.
The etching is a cool concept. I thought machining of laser cutting were the only viable options. I'll still need to get a geometry,
As for a generator, I'm not too worried. I'm a EE that's designed several Brushless controllers, and using them for efficient generators is duck soup. I just need to manage teh bearings and vibration so that it lasts.
Any ideas?
-Mike
