Comparing Oxidising Power: MnO4 - versus MnO2 and ClO4- versus ClO-
  • Thread starter Thread starter jd12345
    Power
ClO- is identified as a stronger oxidizing agent than ClO4- due to its lower stability and higher reactivity, which allows it to be more easily reduced. In contrast, ClO4- possesses resonance structures that enhance its stability, making it less prone to oxidation. The discussion draws parallels with manganese compounds, noting that MnO4- is indeed a stronger oxidizing agent than MnO2, but the comparison between chlorine and manganese is deemed too simplistic. The differing chemical behaviors of Cl and Mn highlight the complexities in oxidation potential, emphasizing that straightforward comparisons between different elements or compounds can be misleading.
jd12345
Why is ClO- more oxidising than ClO4 - ? I related this to MnO4 - and MnO2
MnO4 - is more oxidising than MnO2 so ClO4- should also be more oxidising than ClO- too
Can you give me reasons to why MnO4- is more oxidising than MnO2 but ClO4- is not a stronger oxidising agent than ClO-
Chemistry news on Phys.org
Your HYPOTHESIS is wrong. Such easy comparison cannot be made ! Think about it...
Cl-O-O-O-O and Cl-O
- are bonds...
Now think which one can easily be reduced... Also same thinking should take place while analyzing manganese compounds.
sankalpmittal said:
Cl-O-O-O-O and Cl-O
- are bonds...
This is completely off. Please don't comment on things you have no idea about.
Mn and Cl are way too different for such a simple comparison.
Ok can you give reasons of why clo- is more oxidising than clo4-
also why mno4- is more oxidising than mno2
Clo4- definitely has resonating structures and is more stable so less oxidising than clo-
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
