How to Calculate the Fatigue Limit of Leaf Springs?
To calculate the fatigue limit of leaf springs, one must use stress equations specific to leaf springs to determine the stress values. These stress values can then be applied to the S-N curve relevant to the material being used. There is no shortcut; a thorough understanding of material properties and stress analysis is essential. The process involves correlating cycles to failure with the derived stress values. Accurate calculations are crucial for ensuring the durability and performance of leaf springs.
fpdlskf
Hi to all.
How would I go about calculating the fatigue limit of leaf springs?
Is there an equation out there in the form of
N, cycles to failure= f(variables, material properties)
Or will I have to use the Stress equations for leaf springs and use that stress value and
then look up a S-N curve for that particular material??
Tnx in advance.
There are no shortcuts in this life. You will have to use the stress equations for the springs and then use those stresses in the S-N curve for the material. That's what you'll be getting the big bucks to do!
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
