Calculate electric field of infinite slab
zezima1
An infinite plane slab of thickness 2d lies in the xy-plane with −d<z<d. Its charge density is given
as ρ = kz2 for −d<z< d and zero otherwise.
(i) Find the electric field, E(z), for all z.
Gauss' law
This problem is pretty easy to do with a gaussian surface. However. I wanted to know if I could also do it by calculating the field directly from coulombs law (I know it would be far more tedious but I'm just curious) with the integral
1/4∏ε0Vρ/r2dv = 1/4∏ε0∫∫∫ρ/(x2+y2+z2) dxdydx where the integrals of y and x run from -∞ to ∞ and the integral of z runs from -d to d.
But if so, this integral would only hold for being outside the slab right?
Gauss' law
The integral
$$\frac{1}{4\pi\epsilon_0}\int_V \frac{\rho}{r^2}\,dv,$$ where r is understood to be the distance from the volume element dv to the point at which you're trying to calculate the E field, isn't quite correct because you're not taking into account the vector nature of the electric field. The integral as written sums the magnitude of the electric field, but that's not how superposition works for the E field.
Even if we ignore that error, your second integral
$$\frac{1}{4\pi\epsilon_0}\int_V \frac{\rho}{x^2+y^2+z^2}\,dv$$ doesn't equal the first one because r2 isn't equal to ##x^2+y^2+z^2##.
Still, your basic idea is right. You can calculate the electric field using this method, though as you noted, it's tedious.
but x2+y2+z2 does equal r2?
But you are right I didn't put account for the vector nature. from symmetry we see that the field must point along the z-axis. So therefore multiplying by a cosine(which can be written as a ratio of z and r) should do the trick - then I would be correct right?
Oops, there was a typo in my last post. Forgot the square.
##\sqrt{x^2+y^2+z^2}## is the distance from the origin to the point (x,y,z). Unless you're calculating the electric field at the origin, it's not equal to the distance r which appears in Coulomb's law.
Gauss' law
You could try to solve the Poisson equation, del2V = -ρ/ε0.
At least that's not a vector integration, but maybe a painful 2nd order partial differential equation. You'd have to do it twice: once for inside the slab where ρ = ρ, then again outside the slab where ρ = 0.
Then E = -del V.
Bonne chance.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
