Tangent to the Point: Solving for b and c
  • Thread starter Thread starter danne89
    Point Tangent
To find the values of b and c for the parabola y=x^2+bx+c such that the line y=2x is tangent at the point (2,4), it is established that the parabola must pass through (2,4). The derivative of the parabola at x=2 must equal the slope of the tangent line, which is 2. By calculating, b is determined to be -2, and substituting back gives c as 4. Thus, the equation of the parabola is y=x^2-2x+4, confirming the tangent condition at the specified point. This solution effectively demonstrates the relationship between the parabola and the tangent line.
danne89
Consider the pababola y=x^2+bx+c. Find the values of b and c such that the line y=2x is tangent to the point (2,4).
I've no clue at all...
Really, no clue at all? Did it not occur to you that if the line is tangent to the parabola at the point (2,4), then the parabola must go through (2,4)- that is, that
4= 22+ b(2)+ c.
Has no one told you that the derivative at a point IS the slope of the tangent line at that point? What is the slope of the line y= 2x? Can you find the derivative of
y= x2+ bx+ c at x= 2?
You have y = 2x as the tangent line.. and you know that y' = 2x + b and thus you can substitute x = 2 into y' to get y' = 4 + b and from the question you know y' = 2... and so 2 = 4 + b; b = -2
Next step is finding c, just plug in:
4 = 4 - 4 + c
c = 4
And the parabola is y = x^2 - 2x + 4
And to test it..
y' = 2x - 2
And at the point (2,4); y - 4 = 2(x-2); y = 2x - 4 + 4 = 2x
And that's the answer...
Or I could be completely wrong. :approve:
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
