Mixing water at different temperatures
  • Thread starter Thread starter MoniMini
    Mixing Water
To find the final temperature when mixing 1 kg of water at 10°C with 5 kg of water at 80°C, the principle of conservation of energy is applied, assuming no heat loss. The final temperature can be calculated using the formula T = (T1*M1 + T2*M2) / (M1 + M2), which represents a weighted average based on the masses and initial temperatures. The specific heat of water is considered constant for this calculation, simplifying the energy balance. The final temperature obtained from the calculation is 63.8°C, confirming the accuracy of the method used. This approach effectively addresses the problem of mixing water at different temperatures.
MoniMini
Hello all,
I'm having trouble solving the given problem.
"Assuming that no heat is lost to the surrroundings, what will be the final temperature when 1 kg of water at 10°C is mixed with 5 kg of water at 80°C"
Taking the mean of the 2 fluids will not help here since their mass is different.
I don't know any other formula regarding such problems.
Thank You,
~MoniMini
Science news on Phys.org
MoniMini said:
Hello all,
Thank You,
~MoniMini
You can say that the specific heat of water is constant. This is not exactly right, but it will be very close. That means the change in internal energy is proportional to its change in temperature. Its also proportional to the amount of water you have. So \Delta U_1=K M_1 (T_1-T) and \Delta U_2=K M_2 (T_2-T) where \Delta U_1 is the change in internal energy of the first case (which you don't know), T_1 is the initial temperature for the first case (10°C) , T is the final temperature for the first case (what you are trying to find), and M_1 is the mass in the first case (1 kg). Also, \Delta U_2 is the change in internal energy of the second case (which you don't know), T_2 is the initial temperature for the second case (80°C) , T is the final temperature for the second case (what you are trying to find), and M_2 is the mass in the second case (5 kg). K is some constant, but don't worry about it, it cancels out. Notice that the final temperature is T in both cases, because when you mix them together, they both go to the same temperature. Finally, you know that no heat was added or subtracted, so the total change in internal energy has to be zero. That means \Delta U_1+\Delta U_2=0 Now you have three equations and three unknowns T, \Delta U_1 and \Delta U_2 and you can solve for the final temperature. T=\frac{T_1M_1+T_2M_2}{M_1+M_2} Its just a "weighted average" of the two temperatures. If both the masses were equal, you would have just the average, (T_1+T_2)/2
I found the specific heat capacity online. http://www.engineeringtoolbox.com/water-thermal-properties-d_162.html
The heat capacity barely changes from 10 to 80 degrees.
But if you wanted to factor the heat capacity change, you could integrate the heat capacity across temperature to get internal energy versus temperature per mass. Then add up the initial energies and this is equal to your final energy.
Thanks a TON! You explained it really well.
I got the correct anser. I don't know how to type in the mathematical symbols and all, but on paper I calculated and the result was 63.8°C which is the correct answer.
Thanks again :)
~MoniMini
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
