A right circular cone is inscribed in a hemisphere.
A right circular cone is inscribed in a hemisphere, and the combined surface area of the hemisphere and the cone's base is increasing at a rate of 18 in² per second. The surface area of the hemisphere is calculated as 2πr², leading to a total surface area of 3πr². By determining the rate of change of the radius (dr/dt) from the surface area increase, one can find the rate of change of the cone's volume (dV/dt) using the volume formula V = (1/3)πr²h. The height of the cone is equal to the radius of the hemisphere, simplifying the volume calculation to V = (1/3)πr³. The discussion also touches on formatting issues with code symbols used in the conversation.
pringless
A right circular cone is inscribed in a hemisphere. The figure is expanding in such a way that the combinded surface area of the hemisphere and its base is increasing at a constant rate of 18 in^2 per second. At what rate is the volume of the cone changing when the radius of the common base is 4 in?
Mathematics news on Phys.org
Are you sure this shouldn't be under "homework help"? :smile:
I assume that the cone is inscribed in the hemisphere so that its base is the circular base of the hemispher.
If I remember correctly, the surface area of a sphere is 4 &pi r2 so the surface area of a hemisphere is 2 &pi r2 and the "combinded surface area of the hemisphere and its base" is A= 3 &pi r2. Knowing that dA= 18 square inches per second, you should be able to find the rate of change of r from that.
The volume of a right circular cone is given by V= (1/3) &pi r2h (I confess I looked that up). In this case, the height of the cone, as well as the radius of its base, is the radius of the hemisphere so V= (1/3) &pi r3. Since you have already calculated dr/dt, you can use that to find dV/dt.
(Why are the "& codes" that Greg Barnhardt noted not working for me?)
do they need to be (and are they) followed by semicolons?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
