Nyquist Criterion: Determine Order of Open Loop Transfer Function W(s)
  • Thread starter Thread starter stefaneli
The discussion focuses on using the Nyquist criterion to determine the order of the numerator and denominator of an open loop transfer function W(s). It suggests that plotting a Nyquist chart can help visualize the effects of varying poles and zeros on the system's stability. Each pole contributes a maximum of 90 degrees of lag, which is important for analysis. However, it concludes that Nyquist alone may not provide a definitive answer to the original question about identifying the number of poles and zeros. Exploring additional resources or tools may be necessary for a comprehensive understanding.
stefaneli
I was wondering if it's possible to know the difference between order of numerator and order of denumerator of open loop transfer function W(s) using Nyquist criterion ('stable' poles/zeros are bothering me; basically is there a way to find out a number of poles and zeros of W(s))? I hope I've explained my problem good enough...Any help is appreciated.:)
Perhaps if you plot the Nyquist chart for some examples you concoct you might be able to answer this. Start off with a few poles, then introduce a zero midway between the poles and see what changes on the Nyquist plot, and so on. (Bear in mind that each pole contributes at most 90 degrees of lag.) If you search online I bet you'll find a free Nyquist plotter.
I'm not pretending to know the answer; but that's how I would go about investigating it. Good luck!
Here's a basic free plotter. Having played around with it, I don't think Nyquist alone is going to help with what you asked. http://www.facstaff.bucknell.edu/mastascu/eControlHTML/Problems/Freq/Interactive/Freq6NyquistP01Int.htm
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
