How does surface size affect wind pressure on a sail boat?
Wind pressure on a sailboat or wind turbine is influenced by the surface area and the wind speed. Bernoulli's equation can be applied for deformable surfaces like sails, while rigid surfaces require consideration of Newton's laws due to wind deflection. The pressure exerted by wind on a surface changes with wind direction, speed, and the surface's characteristics. In the case of a 120m span wind turbine with a 12,000 m² surface area, adjustments in wind speed are necessary to maintain consistent pressure if the surface area is decreased. Understanding these dynamics is crucial for optimizing performance in both sailing and wind energy applications.
jacques dichi
Hi forumers,
I've got a question,and of course all proper answers are welcome,
I think however a sailboat designer/engineer would quickly know
what I'm talking about.
I'd like to know what is the pressure/push of a 10 mph (16 km/h)
wind on 12,000 sq.mt. surface ,and how to figure this out if I change
the parameters ?
Thks. & Happy Easter
J.D.
You can use Bernoulli's equation to calculate the stagnation pressure at that wind speed.
Thk. u Russ for yr. reply I'll try bernoulli as suggested - if he fails me - I'll come back to u
Hey,
It depends on the surface you are talking about. If it is a sail, then it can deform so that the velocity of the wind is practically zero on the sail surface. So Bernoulli's principle would hold good. But if it is a rigid surface, the wind will get deflected and the force is based on Newton's 2nd law. Besides, this value also changes with the direction of wind and speed of the boat(or surface) and compression of air.
Do let me know if you want a general equation for the same :)
sci-phy said:
Hey,
thks. for your answer. - I think according to it I might have misled a few people with the phrasing of the question or my comparison - sorry for that.
What I have is a 120m. span 3 wing wind turbine -approx. 12,000 m^2 surface - it does not deform like a sail and it is not rigid like a wall although when rotating it could be considered as such - and a 10 mph wind.
If I decrease the surface,how have I got to increase the wind in order to obtain the same "pressure/push" ?
Pls. bear with me,
Thks.
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
