Collision and Friction: Theoretical Q with Practical Implications
The discussion revolves around modeling the collision response of a mass point approaching a plate at an angle, considering the coefficient of restitution and friction. It questions whether the collision response can be simplified to inverting the normal velocity and applying the coefficient of restitution, or if friction must also be accounted for due to the forces exerted during the impact. The participants note that if the mass point bounces without sliding, energy loss due to friction may not occur, as displacement is zero. They reference literature on impact mechanics for deeper insights and consider the potential energy storage in springs between mass points. The conversation highlights the complexity of accurately modeling collision dynamics in physics.
Simon666
Theoretical question with practical implications (trying to model yarn as mass points connected with spring systems and need to get collision response with objects right):
A mass point approaches a plate under an angle. You have the coefficient of restitution β and the friction coefficient μ. You know the initial speed v of the point and can decompose it in normal component vN and tangential component vT to the surface.
What is the collision response of the mass point?
Just inverting the sign of vN and multiplying with β?
Or is there also a friction response since technically the surface and mass point exert forces on each other in an infinitely small amount of time, so an impulse reaction, and I also need to add -μ*vN to the tangential component or something?
Not really my field. Whole books are written on impacts, Google books suggests "Impact Mechanics" By W. J. Stronge
If the mass points bounce off without sliding over the surface then I don't think any energy is lost due to friction (work = force * displacement but the displacement is zero?).
So I think you just need to use the normal component of the velocity and the coefficient of restitution to work out the normal component of velocity after the impact.
Page 97 appears to discuss this...
http://books.google.co.uk/books?id=...oefficient of restitution at an angle&f=false
Edit: However having read that bit again ... Can the springs between the point masses store energy?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
