Q about electric field between two parallel plates
The discussion centers on the electric field between two parallel plates, highlighting two expressions: E = σ/ε0 and E = V/d. The first expression indicates that the electric field is constant and independent of the distance d when charge Q is constant. The second expression shows that while E = V/d, the potential V can also vary with d, meaning there is no contradiction between the two formulas. The relationship involves capacitance, where maintaining a constant charge while increasing distance requires work, resulting in an increased voltage, but the electric field remains unchanged.
asdff529
There are two expressions of electric field between two parallel plates,say one carries Q and another carries -Q
Then the electric field between them=σ/ε0
But there is another expression that E=V/d where d is their distance of separation
What are the differences between them?And what are the conditions when using either of one?
Thank you!
Consider Gauss's law \oint \vec{E}\cdot\hat{n}da=\frac{q}{\varepsilon_0}.
Now take, as a Gaussian surface, a rectangular cube which includes only part of one of the planes and is far enough from the edges. The charge that it includes is q=lw\sigma where l and w are dimensions of the part of the cube which is parallel to the charged planes.From the symmetry, we know that the electric field is perpendicular to the plane of the cube parallel to the charged planes and is constant all over it and so the surface integral is just E lw and so we have E=\frac{\sigma}{\varepsilon_0}.
Now consider V=-\int_a^b \vec{E}\cdot\vec{dr} which is used for finding the potential difference between points a and b from the electric field.If electric field is constant along the way and isn't changing direction,the integral will be just the product of electric field and path length and we will have E=\frac V d. As you saw in the last paragraph,the electric field between the planes was constant along their separation and so the formula E=\frac V d can be used in that case.For example you can have V=\frac{d\sigma}{\varepsilon_0} for the potential difference between two points between the charged planes with separation d.
Its not that they are two different formulas.They're just in terms of different things.
Likes 1 person
Now consider V=-\int_a^b \vec{E}\cdot\vec{dr} which is used for finding the potential difference between points a and b from the electric field.If electric field is constant along the way and isn't changing direction,the integral will be just the product of electric field and path length and we will have E=Vd. As you saw in the last paragraph,the electric field between the planes was constant along their separation and so the formula E=Vd can be used in that case.For example you can have V=\frac{\sigma}{d\varepsilon_0} for the potential difference between two points between the charged planes with separation d.
but my teacher said if we use E=σ/ε0 and Q is kept constant,the electric field is independent of d.
it seems that there is a contradiction,because E=V/d as well,where am i wrong?
There is no contradiction. E=V/d doesn't mean E depends on d! Because V can be a function of d as well.
Likes 1 person
There is no contradiction. The one expression can be re-arranged into the other.
The quantity in this relationship is Capacitance (C) and Q = CV
You can replace this by σ=c0V
where c0 is the capacitance per unit area.
Keeping Q constant and increasing d will require work, so V will have increased. The Volts per Meter will remain the same. Alternatively, separating the plates will decrease the Capacitance, which implies an increase in V.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
