How to Determine the voltage polarity of inductor in a circuit?
The voltage polarity across an inductor is the same as that across a capacitor when they are in parallel, as they share the same voltage. In a circuit with an inductor, capacitor, and resistor, the voltage polarity across the inductor can be determined by the direction of current flow, which is influenced by the charged capacitor. The sum of the voltages around the circuit must equal zero, leading to the equation VC + VL + VR = 0. Redrawing the circuit can clarify the relationships between components and their polarities. Ultimately, energy flows from the capacitor through the inductor to the resistor, where it is dissipated as heat.
smatik
The Voltage polarity across the inductor is same as that across the capacitor since both are in parallel and the voltage across them must be same.
But when Inductor, capacitor and resistor are connected as shown in the second figure what would be the voltage polarity across the inductor and why? (right end of inductor 'r'=+ve or -ve?)
The sum of the voltages around the circuit must be zero.
The battery causes a current to flow, the direction of flow sets the polarity of the components.
I've indicated The direction of current in second figure(Is it correct?). The current is due to charged capacitor(you can see the charge on the capacitor is Q). So what voltage equation would you write?
Your circuit diagram is confusing you. Redraw the diagram with the capacitor on the left (with positive terminal up), the resistor on the right and the inductor at the top. The bottom line is a reference voltage.
Energy from the capacitor on the left flows through the inductor to the resistor on the right where it is dissipated as heat.
Measuring around the circuit, VC + VL + VR = 0
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
