Where does surplus current go if i switch off appliance
  • Thread starter Thread starter jaus tail
    Current Switch
When appliances are switched off during initiatives like "Green Day," the excess current does not go anywhere; instead, it results in a decreased demand registered at the power control station. Power generators are adjusted by control stations that regulate output based on current demand, similar to how a throttle works in a car. The discussion highlights that increasing resistance in a circuit reduces current, but emphasizes that power is what consumers pay for, not current itself. The analogy of water in pipes is misleading, as electrical current behaves differently in terms of demand and supply. Overall, the initiative aims to reduce power consumption effectively without causing instability in the electrical grid.
jaus tail
Hello everyone,
I've read about green day when government says to switch off appliances for an hour in evening.
But if everyone switches off appliance, then where will all that current go? We cannot stop generator so quickly.
It's like a dam is giving water to three pipes, in full force. Suddenly two pipes are removed, so wouldn't that one pipe carry all the water and if that one pipe doesn't carry water, wouldn't dam explode since there's more water than it can contain?
Who tells the generator, to supply less current?
Also if I have a single load which with a power supply. Load would be resistor(i hope I'm right.) so if i increase resistance in series(which is like adding load) then the total resistance increases, so current should reduce.
I asked professors but they just said that green day works as news papers say so.
The wave reflects off the end of the open circuit. It registers as a decreased demand at the main control.
Note: nothing like water in pipes - if there is nowhere to go, the current does not go anywhere.
There is usually some sort of control station somewhere - maybe owned by the power company - which coordinates the different power stations. In each station there is a control board to regulate which generators are going and how fast they go - like the throttle in a car. It amounts to some people watching a dial and turning a knob - if the dial gets higher, they turn the know up and if it gets low they turn the knob down.
There is a nice demonstration on video somewhere showing a bicycle powered house.
http://road.cc/content/news/11779-cyclists-power-family-home-bbc-show-highlight-energy-wastage
The principle is the same.
You are interested that big loads should draw more power, but a bigger load at the same voltage draws less current ... suggesting less power is drawn?
Note: in the video, when the shower turns on, adding load to the system, the voltage supplied drops.
The cyclists have to pedal harder to keep the voltage high enough to power the shower.
You pay for power, not current.
The green day reduces power consumption.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
