What Makes Hydrogen Highly Flammable and Carbon Strong?
  • Thread starter Thread starter Mozart
    Hydrogen
Certain gases are highly flammable due to their low kindling points and the ease with which they can react with other substances. Hydrogen, in particular, is extremely combustible because it readily bonds with other atoms, requiring only a small activation energy to initiate a reaction, such as the formation of water when hydrogen gas reacts with oxygen gas. The kindling point is influenced by molecular structure and the energy required to start a reaction, with gases generally exhibiting lower kindling points compared to solids.Regarding carbon, its strength varies significantly depending on its allotrope. Graphite, while composed of carbon, is brittle due to its hexagonal bonding structure, allowing layers to slide over each other easily. In contrast, diamonds possess a rigid and tightly bonded structure, making them the hardest natural material. Fullerines, another form of carbon, consist of spherical arrangements and are being explored for applications in nanotechnology, demonstrating that the strength of carbon is largely determined by its bonding configuration.
Mozart
Why are certain gasses so flammable? What makes hydrogen so combustious? Is it because they have low kindling points? If so what determines a kindling point, and are gasses known to have lower kindling points compared to solids?
Here is an extra curricular question: What makes Carbon so strong?
That is a little off topic but I don't want to have to make another thread and crowd up the boards with my ignorance. Help me rid myself of my incompetence.
Chemistry news on Phys.org
I would assume hydrogen is so flammable because it so readily wants to bond with other atoms. If the reaction has a low activation energy, then it will be easy to start. For example, hydrogen gas and oxygen gas need only a small spark to make water. the key is having the needed components for the reaction.
Carbon has 3 allotropes,
-Graphite
-Diamonds
-Fullerines/"Buckeyballs"
Graphite is not strong at all, it is quite brittle, like in pencil "lead". When carbon is in the form of graphite, it forms hexagonal bonds with other carbon atoms, that form in planes than can easily break.
Diamonds however are the hardest thing on Earth if I am not misstaken. It forms very rigid, tight bonds with other carbon atoms.
Fullerines form "balls" of carbon. You almost need a picture or 3D model to understand what they look like, but these two are strong. They are being considered in making new types of nano wires and various other things out of tubes make out of the "balls" or carbon.
It is all about how the carbon is bonded.
