Potential difference in a single battery
When measuring the potential difference across a single battery connected in series with another battery, the voltmeter will display the emf of the single battery, not the sum of the emfs of both batteries. This is because the voltmeter measures the voltage drop across the specific battery it is connected to, which is influenced by its internal resistance. The internal resistance of the battery can affect the reading, especially under load. Drawing out the circuit can help visualize the connections and clarify how the voltmeter interacts with the batteries. Understanding these principles is crucial for accurate measurements in electrical circuits.
Miraj Kayastha
When we place a voltmeter across a single battery which is connected to another battery in series, does voltmeter show the emf of the single battery or the sum of emf of both the batteries?
Why not draw out the circuit and work it out?
Recall that a real battery is modeled by an ideal battery in series with a small resistance.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
