How to apply boundary condition in generalized eigenvalue problem?
Boundary conditions, specifically Dirichlet and Neumann, are typically applied to the Load Vector in finite element method (FEM) formulations. In the context of a generalized eigenvalue problem for the Scalar Helmholtz equation, natural boundary conditions may suffice when dealing with perfectly conducting walls. However, when extending the application to anisotropic, inhomogeneous media using vector FEM with edge elements, boundary conditions become essential to avoid spurious modes. To implement these conditions without a Load vector, one can either remove degrees of freedom (DOF) from the system or apply a large stiffness value on the diagonal of the stiffness matrix. Care must be taken to select an appropriate stiffness to prevent introducing non-physical solutions.
mdn
Hi all,
Generally boundary condition (Dirichlet and Neumann) are applied on the Load Vector, in FEM formulation.
The equation i solved, is Generalized eigenvalue equation for Scalar Helmholtz equation in homogeneous wave guide with perfectly conducting wall ( Kψ =λMψ ), and found, doesn't need to apply boundary condition as here, i encounter natural boundary condition.
I want to apply this equation for anisotropic, inhomogeneous medium, and read that, i have to use vector fem with edge element and not nodal element that i used in my procedure,
to avoid non physical solution (spurious mode).
and here boundary condition are necessary, now i confused, how to apply boundary condition if there is no Load vector in formulation? and as per my reading, there is no way to apply BC on Stiffness and Mass matrix.
thanks in advance.
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
In eigenvalue problems you can apply a zero Dirichlet boundary condition by removing the DOF from the system of equations. That means forming smaller matrices without the row and column of that DOF.
Alternatively, you can put a large stiffness on the diagonal. This connects the DOF to ground by a stiff spring. The disadvantage is that you have to choose a stiffness high enough that it won't cause spurious modes in the frequency range you're interested in.
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
