Confusion in understanding how electric heating works
To calculate the heat pulse (q) generated by the heater, use the formula q = Power (W) × time (s). Given a power input of 0.368W over 180 seconds, the total heat delivered is 66.24 Joules. The discussion highlights that using resistance wire is more effective than copper for heating applications due to copper's high conductivity. Additionally, to verify the power output, the formula Power = Volts² / Resistance can be employed. The mention of "distance r from the axis" appears unrelated to the primary calculations and may pertain to temperature measurements.
alditi
I'm working on a project in which I have to build a tiny 4 cm long heater. I did this with copper-windings stuffed in a tiny steel rod. Now I know the power input into this heater is 0.368W, at constant voltage 1.5 volts and the resistance of the heating element is 6.1ohms for a time of 180seconds.
I want to know how to calculate the heat pulse (q) generated in this time. What's the formula for doing this? The internet is unclear. Take this at any distance r from the axis.
If there is nothing else in the circuit then the same power input is output. Power is joules of energy per second. So, if you are giving it .368 joules per second over 180 seconds, how many joules is that altogether? Its like if you can run 5 miles per hour and you run 3 hours how many miles have you run?
Did you really use Copper Wire? It is more normal to use resistance wire because copper is such a good conductor that it does not get hot until you put a massive amount of current through it.
Total heat delivered (Energy, in Joules) will be Heater Power in Watts times time in seconds. If you are told the Power, then, as long as you are using the right supply voltage, you don't need to do any more electrical calculations. To check that the Power you are given agrees with the Volts and Resistance, you can use
Power = Volts Squared / Resistance
PS what has "distance r from the axis" got to do with this? IS this something to do with the measurements on the water temperature?
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
