Are these equations describing causal or noncausal systems?
  • Thread starter Thread starter ENGRstudent
    Systems
The discussion revolves around identifying whether specific equations represent causal or noncausal systems. Equation A (y(t)=x(t-2)) is confirmed as causal due to its reliance on past input values. Equation B (y(t)=x(-t)) is deemed noncausal since it depends on future input values when t is negative. Equations C (y(t)=x(at), a>1) and D (y(t)=x(at), a<1) are debated, with the consensus that D can be noncausal if a is negative or less than 1, while C remains causal for positive values of a. The conversation emphasizes the importance of understanding causality in relation to the timing of input and output signals.
ENGRstudent
I'm working on homework, and I think I can explain the difference between causal and noncausal systems, but I don't know if I'm accurately recognizing them mathematically.
Here are my homework questions and my answers:
Are the systems described by the following equations with input x(t) and output y(t) causal or noncausal?
A) y(t)=x(t-2) : CAUSAL; involves a delay of the signal in real time.
B) y(t)=x(-t) : NONCAUSAL; causal signals do not exist before t=0 (I think?).
C) y(t)=x(at), a>1 : CAUSAL; a is never negative.
D) y(t)=x(at), a<1 : CAUSAL; a may be any real number between 0 and 1.
Can anyone verify or correct me on any of these?
Nobody can help me on this?
I think some of the answers you gave are wrong. As I understand it, and it has been a while since I took this class, a casual system is one whose current value only depends on the present and past values of the input.
So A is correct. The present value of y only depends on past values of x, or more specifically, x's that occurred 2 time units ago. i.e. for t=2, y(2)=x(0). Using this technique perhaps you can find the problems in your other answers.
Also, usually when I solve systems I don't restrict myself to t>=0. In general I will set the signal value to 0 when t<0 but this is not the same as saying the signal does not exist before t=0 and it does not mean t cannot be negative. Your instructor may have confined your range to t>=0 though.
Thank you, es. My answer for D was incorrect.
My pleasure however I think you may still have some errors hiding.
What are your opinions of the following points?
Equation C with a=5 and t=1
Equation D with a=-1
Equation D with a=1/2 and t=2
Well, I'm still learning, but here goes...
Equation C remains causal with a=5 and t=1 because the output still exists after t=0.
Equation D with a= -1 is noncausal because it places the signal before t=0.
Equation D with a=1/2 and t=2 becomes causal because once again, it places the resultant signal after t=0. But since the parameter given was a<1, the system is noncausal because it must hold true for all values of a<1.
Or something. :)
Ah. I understand where the confusion is now.
Causality does not reflect how events relate to t=0. Causailty relates times to each other. It means the output signal only depends on values that are occurring right now or occurred in the past.
Reusing our examples:
1: y(t)=x(t-2) is casual
the output, y, only depends on x's which occurred two time units ago, aka
in the past. for t=10, y(10)=x(8) which means the value of the output at
time 10 is the same what the output was at time 8. notice both values are
greater than t=0
2: y(t)=x(t) is casual
i just wanted to throw this into show that the output can depend on what
is happening right now and still be casual
3: y(t)=x(-t) is non-casual
when t<0, say -2, y(-2)=x(2). This means the value of the output at time
t=-2 is equal to the value of the input at time t=2. However t=2 occurs
after t=-2. This means the output depends on something which hasn't
happened yet, a future value. This is what makes equation three non-
casual.
4: y(t)=x(at), a>1 is non-casual
let's pick an example, a=5 t=2, here y(2)=x(10). Again, the output
depends on a values which occurs in the future, t=10 occurs after t=2.
All the t's here exist after zero but it is still non-casual.
Note, there are t's which make equation 3 casual. For instance t=0. However if only one point in the range is non-casual then the entire system is non-casual (at least this is how I always do it). If you require the system to become casual then you could try restricting the range. In our example you could say t is only allowed to be zero.
Are you allowed to take t<0. I don't think that would be physically correct or physically make sense.
For that matter for e.g. 4 that you have if we pick a = 5 and t = -2 (t<0) then we have y(-2) = x(-10) which means that the output at -2 depends on a value that occurred earlier -10 thus would make the system causal. What is the difference can you explain? Plus what would you think if a was constrained to only a<1?
FYI...this thread is 4 years old. :wink:
CS
oops sorry i didnt even notice. thank you ;)
