Finding Time and Vf: Car chase problem
Kyle drives at a constant speed of 45.0 m/s, while Cameron starts his chase after a 4-second delay with an acceleration of 2.00 m/s². To determine how far Cameron must drive to catch Kyle, one must calculate their positions over time, particularly after the initial delay. Cameron will initially be 180 meters behind Kyle due to the delay, but he will gain ground as his speed increases. The discussion emphasizes the need to apply kinematic equations to find the time, distance, and final velocity for Cameron's pursuit.
Benny98
Here's the problem I was given:
Kyle is driving at a constant 45.0 m/s when he passes his street racer friend, Cameron. After a 4.00 second delay to get the car started and into gear, Cameron starts chasing Kyle with a constant acceleration of 2.00 m/s/s. How far will Cameron have to drive to catch Kyle, what will be Cameron's top
velocity, and how long will Cameron drive?
Somehow we are supposed to use the quadratic formula.
We haven't done that in class with this type of problem, only parabolic problems, and I don't know how to correlate the two. (ax^2+bx+c) I don't have enough information to use an equation like Vf=Vi+at or Xf=1/2at^2+Vi+Xi either.
What I've tried so far:
With the three graphs given, I could find the small bit of rectangular area in the first 4 seconds, but that doesn't really help me find anything. I tried different ways of attempting to find the area of the triangle that's formed, but I'm getting answers that don't make sense.
Can someone please explain what I need to do in a step-by-step format? I'm not sure how to start this.
Thank you!
You do.
If Kyle passes Cameron at time 0, what is Kyle's position at time t? What is Cameron's position at time t (for t > 4s)?
haruspex said:
You do.
Kyle would be 45m further than Cameron for each 1 of the 4 seconds (or a total of 180m further) Cameron at t>4s would increase by 2.0m/s/s...
No, I mean using the equations you quoted and said you had not enough information to use.
(This is weird. I replied on this thread 12 hours ago but my reply disappeared so I had to type it in again.)
Beams of electrons and protons move parallel to each other in the same direction. They ______. a. attract each other. b. repel each other. c. neither attract nor repel. d. the force of attraction or repulsion depends upon the speed of the beams. This is a previous-year-question of CBSE Board 2023. The answer key marks (b) as the right option. I want to know why we are ignoring Coulomb's force?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
I treat this question as two cases of Doppler effect. (1) When the sound wave travels from bat to moth Speed of sound = 222 x 1.5 = 333 m/s Frequency received by moth: $$f_1=\frac{333+v}{333}\times 222$$ (2) When the sound wave is reflected from moth back to bat Frequency received by bat (moth as source and bat as observer): $$f_2=\frac{333}{333-v}\times f_1$$ $$230.3=\frac{333}{333-v}\times \frac{333+v}{333}\times 222$$ Solving this equation, I get ##v=6.1## m/s but the answer key is...
