Complex Scalar Field in Terms of Two Independent Real Fields
ghotra
I am working with a complex scalar field written in terms of two independent real scalar fields and trying to derive the commutator relations.
So,
\phi = \frac{1}{\sqrt{2}} \left(\phi_1 + i \phi_2)
where \phi_1 and \phi_2 are real.
When deriving,
[\phi(\vec{x},t),\dot{\phi}(\vec{x}',t)] = 0
I get terms like the following:
[\phi_1(\vec{x},t),\dot{\phi}_2(\vec{x}',t)]
which I need to vanish. It makes sense to me that they should vanish, but how do I show this?
Hmm...I think that we just take that as the quantization condition. That is,
<br /> [\phi_r(\vec{x},t),\pi_s(\vec{x}{\,}&#039;,t}] = i \delta^3(\vec{x}-\vec{x}{\,}&#039;)\delta_{rs}<br />
Is this correct?
Is this correct?
Since \phi_1 and \phi_2 are independent, they'll only be canonically conjugate with their own momenta (the \delta_{rs} on the left). Your equation just states that in combination with the usual commutation relation of the real scalar field.
\phi_1 and \phi_2
are independent fields, so
[\phi_1, \dot{\phi}_2]=0
What is the Poisson bracket between the classical fields ? If you know that, you can canonically quantize using Dirac's rule.
Daniel.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
I am looking at the Laughlin wave function and it contains the term $$\prod_{j<k}^{N}\left(z_j-z_k\right)^q$$ In Wikipedia the lower index on ##\Pi## is ##1\le i<j\le N## and there is no upper index. I'm not sure what either mean. For example would $$\prod_{j<k}^{N}\left(z_j-z_k\right)^q=\prod_{k=2}^{N}\left[\prod_{j=1}^{k-1}\left(z_j-z_k\right)^q\right]?$$ (It seems that ##k## cannot be 1 because there would be nothing to multiply in the second product). I'm not sure what else the...
