A and B have same singular values
  • Thread starter Thread starter Demon117
Demon117
Suppose A is an m x n matrix and B is the n x m matrix obtained by rotating A ninety degrees clockwise on paper (not exactly a standard mathematical transformation!). Do A and B have the same singular values? Prove the answer is yes or give a counterexample.
I have not been able to come up with a counterexample, so I am assuming the answer is yes. But I do not know how to prove that. What properties of Singular Values are there that deal with operations on matrices, like transposing and row-swapping, etc.?
EDIT: Example-
A = \left(\begin{array}{cc} -1 & 2 \\3 & 1 \\ 2 & -1 \end{array}\right)
B = \left(\begin{array}{ccc} 2 & 3 & -1 \\-1 & 1 & 2 \end{array}\right)
It follows that A^{T}A = BB^{T}, so naturally the eigenvalues would be the same for these. Furthermore, the singular values of A and B would have to be the same as well. This is a good idea of what I am trying to prove but I cannot think of how this would be proved in the general case for m x n and n x m matrices A & B...
The second column of B is upside down in your example.
I don't know if this helps, but you can say
B = \left[\begin{pmatrix}-1 & 2 \\3 & 1 \\ 2 & -1 \end{pmatrix} \begin{pmatrix}0 & 1 \\1 & 0 \end{pmatrix}\right]^T
Umm, I don't buy into that. . . According to the definition of B it seems like the second column of B is in fact correct in my example. . . I am not seeing what you are referring to.
Oh, sorry! I rotated counter-clockwise. How about
B = A^T\begin{pmatrix} 0 & 0 & 1 \\ 0 & 1 & 0 \\ 1 & 0 & 0 \end{pmatrix}?
Again, I just want to point out, I don't know how the proof will work out, but this is a way you might be able to generalize for the mxn case what the transformation is.
I'm pretty sure A and B have the same singular values if and only if you can find isometries P and Q such that A = PBQ. The transposing operation and the row swapping operation are both isometries
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
