Ahwleung
- 7
Its not a very difficult problem, and I really only need to know 1 thing about friction; anyways, here's the summed up problem:
(my teacher enjoys making us use constants instead of numbers btw)
A horizontal force F is applied to a small block (mass m1), and it slides across a larger block a length L (mass m2) with the coefficient of friction being u. The larger block in turn slides along a frictionless horizontal surface. Everything starts at rest and the small block starts at the end (left side) of the larger block on the bottom.
We're supposed to find the acceleration of each block relative to the horizontal surfaces, find the time t needed for the small block to slide off the end of the larger block, and find the expression for the energ dissipated as heat due to friction.
Umm, I'd say F=ma, the law of friction (F(kf) = uFn), and also the work equations (for the last question). I can handle all those pretty easily, but I just need something about summing the forces.
We have to draw a free body diagram - here is where I find the problem.
Both blocks have a normal force and a force of gravity (duh).
The 1st block has a Force Applied and a Force of Friction opposing it.
Where I'm getting messed up is on the 2nd block. I don't think Force Applied transfers to the 2nd block - am I right in saying that the only horizontal force on the 2nd block is the force due to friction from the 1st block?
Is this force of friction equal to the Force of friction from the 1st block? Is it Newton's third law?
What doesn't make sense is that friction forces always oppose motion, yet the 2nd block obviously travels in the same direction as the Applied Force.
