A circuit breaker does not work properly?
5 replies · 2K views · last reply
Michael George
I live in Egypt where we use 220V AC / 10 A.
When I turn light off at a circuit breaker, all lights turn off but both mains ( hot & neutral ) become hot.
When I test them, they both have electricity (live), so I afraid to touch them.
I would expect that they both become neutral ... Why does that happen ? and what is the solution ?
Thanks in advance,
I don’t know the exact answer, of course. However I presume in Egypt the rated system voltage is 380/220 V indeed.Most of the dwellings are single-phase supplied.
In my opinion again, it has to be a short circuit or a large receiver in installation.
The circuit breaker will trip for 3 times rated current in 10 seconds.
In 10 sec. at 30 A a10 A circuit breaker could be hot.
If the lights are off -let's take these as incandescent bulbs- it could be at least 50% drop.
If at the end of a 100 m conductor of 1.5 mm^2 copper you'll connect a 3300 W receiver you'll get 30 A at the circuit breaker and a voltage drop of 50% [that means 110 V] for at least 10 seconds before it trips.
Make sure that the circuit breaker box is properly grounded. If is is not the neutral wires can become "hot" due to feedback from other circuits.
DEvens said:
Is your 220V AC a three phase system?
No, My house is a single-phase supplied. In Egypt, We have two mains only (hot and neutral). We don't have the third wire (ground) which is for safety.
You need to consult a licensed electrician to figure out your problems with your house wiring. Thread is closed.
