A conducting loop around a magnetic field
The discussion centers on a conducting loop with two light bulbs placed in an increasing magnetic field. Participants initially questioned whether the bulbs would glow, considering the magnetic field's strength changes but not its position. It was concluded that the changing magnetic flux through the loop induces a current, causing the bulbs to light up. Furthermore, there is consensus that both bulbs would have the same brightness, as no differences in resistance were mentioned. The key takeaway is that the induced current from the changing magnetic flux results in both bulbs glowing equally bright.
Xaspire88
A conducting loop around a magnetic field contains two light bulbs. as shown int the figure. The wires connecting the bulbs are ideal. The magnetic field is increasing rapidly.
A. Do the bulbs glow? why or why not?
B. If they glow, which bulb is brighter? or are they equally bright? explain.
at first i thought that they would glow because the B-field was changing. but then i though yes it is changing in strength but not in position relative to the loop. So then that led me to believe that there would be no induced current and the bulbs would not glow. Just trying to confirm if I'm correct or not. Thank you
link to the diagram <http://img130.imageshack.us/img130/9750/conductingloopzc9.jpg>
Is the magnetic flux through the loop of wire with the bulbs changing? If so, then a current goes through that wire...
So even though the field is not changing position relative to the wire there is still an induced current.. hm well the flux is changing.. it is increasing as the magnetic field increases. so yes the bulbs would light up(because of what you have said) and i would assume that they would be of the same brightness. Nothing says whether or not one has more resistance than the other.
yeah, I agree. seems to me like the bulbs light up and they have the same brightness.
