A couple waves questions that my class can't get
The discussion revolves around solving problems related to simple harmonic motion and springs. Key points include determining the maximum speed of a mass connected to a spring, as well as its speed at various compression and extension points. The conservation of energy principle is suggested as a method to solve these problems, specifically using the equation E = (1/2)mv² + (1/2)kx². For the car suspension problem, participants are advised to calculate the equivalent elastic constant and the frequency of oscillation using the formulas Mg = kx and 2πν = √(k/m). Understanding these concepts and equations is essential for solving the posed questions effectively.
Sny
A mass of 0.39 kg connected to a light spring with a spring constant of 22.2 N/m oscillates on a frictionless horizontal surface. If the spring is compressed 4.0 cm and released from rest, determine the following.
(a) the maximum speed of the mass
(b) the speed of the mass when the spring is compressed 1.5 cm
(c) the speed of the mass when the spring is stretched 1.5 cm
(d) For what value of x does the speed equal one-half the maximum speed?
When four people with a combined mass of 280 kg sit down in a car, they find that the car drops 1.00 cm lower on its springs. Then they get out of the car and bounce it up and down. What is the frequency of the car's vibration if its mass (empty) is 2.0 x 10^3 kg?
I don't even know where to start on these, so all I'm asking for is a nudge in the right direction, possibly some formulas or reading material.
These are problems dealing with simple harmonic motion (s.h.m.) and springs. You'll need to read up on those.
Actually all the formulae you will need are :
\ddot x = -\omega^2 x (s.h.m.)
F = -kx (springs)
Find out what those formulae mean, and we'll go from there.
(a) I suggest to use the law of energy conservation: in all points of the trajectory, the total energy must be the same:
(1) E=\frac{1}{2}mv^2+\frac{1}{2}kx^2=const.
I suggest to apply Eq. (1) between the extreme point and the middle one.
(b, c, d) play with Eq. (1) for different points of the trajectory and show us what you obtain!
For the second problem, try to find the equivalent elastic constant of the car suspension with
(2) Mg=kx
and then the frequence of oscillations with
(3) 2\pi \nu=\sqrt{\frac{k}{m}}
(M-combined mass of people, m - mass of the car without people)
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
10K
