Sample Output of 8-bit A/D Converter at 5KHz
  • Thread starter Thread starter EvLer
    Converter Output
An 8-bit analog-to-digital converter (ADC) outputs one byte per conversion, representing the input voltage relative to a reference voltage. For a 5kHz input signal oscillating between 0V and a 5V reference, the output values will range from 0x00 to 0xFF. This means the ADC can produce 256 distinct values corresponding to the input waveform. The specific output values depend on the input voltage at each sampling point. Understanding this relationship is crucial for interpreting the ADC's digital output.
EvLer
Can anyone give me some idea of what is a possible output of analog-digit. converter 8-bit resolution. I don't have an opportunity to plug one in, but need some sample data... Let't say input frequency is 5KHz.
Thanks!
The output of an 8-bit ADC is one byte per conversion period, where the byte value shows where the input voltage is with respect to the reference voltage. The relationship to the reference voltage varies with the ADC, but a typical arrangement would be for the output byte to show where the input voltage is between the reference voltage and ground.
So if you have a 5kHz input voltage that swings between a 5V reference voltage and ground, then the 8-bit output values will vary between 0x00 and 0xFF to follow that input waveform.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
