How can I apply statics principles to solve a problem with unknown forces?
  • Thread starter Thread starter scotthands
    Statics
To solve the problem involving unknown forces, it's essential to accurately determine the angles at point B, as the assumption of a 90-degree angle is incorrect. The tension in the cable should be analyzed along its length, and trigonometric functions can be used to find the correct angle based on the provided dimensions. Once the angle is established, the x and y components of the forces can be calculated using relevant equations while paying attention to their directions. Properly applying these principles will lead to a clearer understanding of the static equilibrium in the problem. Understanding these concepts is crucial for effectively addressing statics problems.
scotthands
scotthands said:
i assumed that there is a 90 degree angle at point B but I'm not sure if that's correct, I'm pretty stumped with this question...i just need a few pointers.
The tension in the cable acts in a direction along its length. You can calculate the angle that it makes at B from the given dimensions using trig. It is not 90 degrees. Once you determine the angle, get the x and y components from your relevant equations, and watch the direction, left or right, up or down.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
