MHB What is the Limit of the Hankel Determinant in a Matrix Challenge Problem?
  • Thread starter Thread starter MountEvariste
    Determinant Limit
The discussion revolves around a challenge problem involving the Hankel matrix derived from the trace of a matrix raised to the power of n, specifically for an r x r matrix A with distinct eigenvalues. It establishes that the limit of the absolute value of the determinant of the Hankel matrix H(n) raised to the power of 1/n converges to the product of the absolute values of the eigenvalues as n approaches infinity. The solution utilizes the Newton sum formula to relate the determinant of H(n) to the coefficients of the polynomial whose roots are the eigenvalues. The final conclusion confirms that the limit is indeed equal to the product of the eigenvalues, showcasing the relationship between matrix properties and determinants. The discussion highlights the mathematical rigor involved in proving this result.
MountEvariste
Challenge Problem: Let $A$ be an $r \times r$ matrix with distinct eigenvalues $λ_1, . . . , λ_r$. For $n \ge 0$, let $a(n)$ be
the trace of $A^n$. Let $H(n)$ be the $r \times r$ the Hankel matrix with $(i, j)$ entry $a(i + j + n - 2)$. Show that
$ \displaystyle
\lim_{n \to \infty}
\lvert \det H(n) \rvert ^{1/n} =\prod_{k=1}^{r} \lvert \lambda_k \rvert
Mathematics news on Phys.org
the trace of $A_n$. Let $H(n)$ be the $r \times r$ the Hankel matrix with $(i, j)$ entry $a(i + j + n - 2)$. Show that
$$\lim_{n \to \infty} \lvert \det H(n) \rvert ^{1/n} =\prod_{k=1}^{r} \lvert \lambda_k \rvert .$$
I'm assuming that $A_n$ in the statement of the problem should be $A^n$.
[sp]Since $A$ has distinct eigenvalues, it is diagonalizable. So its trace is $\lambda_1 + \ldots + \lambda_r$ and the trace of $A^n$ is $a(n) = \lambda_1^n + \ldots + \lambda_r^n$.
Let $x^r + c_1x^{r-1} + \ldots + c_{r-1}x + c_r = 0$ be the equation whose roots are $\lambda_1, \ldots, \lambda_r$. Apply the Newton sum formula $a(k) + c_1a(k-1) + \ldots + c_ra(k-r) = 0$ to each element of the final column of $H(n)$ (where $n>r$) to get $$\begin{aligned}\det H(n) &= \begin{vmatrix}a(n) & a(n+1) & \ldots & a(n+r-2) & a(n+r-1) \\ a(n+1) & a(n+2) & \ldots & a(n+r-1) & a(n+r) \\ \vdots & \vdots & \ddots & \vdots & \vdots \\ a(n+r-1) & a(n+r) & \ldots & a(n+2r-3) & a(n + 2r-2) \end{vmatrix} \\ \\ &= \begin{vmatrix}a(n) & a(n+1) & \ldots & a(n+r-2) & -c_1a(n+r-2) - \ldots - c_{r-1}a(n) - c_ra(n-1) \\ a(n+1) & a(n+2) & \ldots & a(n+r-1) & -c_1a(n+r-1) - \ldots - c_{r-1}a(n+1) - c_ra(n) \\ \vdots & \vdots & \ddots & \vdots & \vdots \\ a(n+r-1) & a(n+r) & \ldots & a(n+2r-3) & -c_1a(n+2r-3) - \ldots - c_{r-1}a(n+r-1) - c_ra(n+r-2) \end{vmatrix}. \end{aligned}$$ For each $k$ with $1\leqslant k\leqslant r-1$, add $c_{r-k}$ times the $k$th column of that determinant to the last column, giving $$\det H(n) = -c_r\begin{vmatrix}a(n) & a(n+1) & \ldots & a(n+r-2) & a(n-1) \\ a(n+1) & a(n+2) & \ldots & a(n+r-1) & a(n) \\ \vdots & \vdots & \ddots & \vdots & \vdots \\ a(n+r-1) & a(n+r) & \ldots & a(n+2r-3) & a(n + r-2) \end{vmatrix}.$$ But that determinant is just $\det H(n-1)$ with the first column shifted all the way to the right. This shows that $\det H(n) = \pm c_r\det H(n-1)$. By induction, $\det H(n) = \pm c_r^{n-r}\det H(r)$.
Therefore $$|\det H(n)|^{1/n} = |c_r|\left|\frac{\det H(r)}{c_r^r}\right|^{1/n} \to |c_r|$$ as $n\to\infty$. But $c_r$ is $\pm$ the product of the roots of the equation $x^r + c_1x^{r-1} + \ldots + c_{r-1}x + c_r = 0$, namely $$\prod_{k=1}^r\lambda_k.$$ So $$\lim_{n\to\infty}|\det H(n)|^{1/n} = \prod_{k=1}^r|\lambda_k|$$, as required.
[/sp]
Opalg said:
Thanks for such a beautiful solution! (Bow)
Yeah, indeed I meant $A^n$. Fixed now.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
19K
13K
10K
15K
11K
13K
