Heating Blue/Yellow Glass: What Happens?
  • Thread starter Thread starter ananthu
    Glass
When heated, red glass glows green, and green glass glows red, due to the relationship between complementary colors in the color spectrum. The wavelengths reflected at room temperature are weakly emitted when heated, leading to this phenomenon. As glass heats further, it transitions from glowing red to a white-hot state. The discussion also raises questions about how blue or yellow glass behaves under heat, but the principles of complementary colors apply similarly. Understanding these interactions clarifies the behavior of colored glass when subjected to high temperatures.
ananthu
When a piece of red glass is heated to high temperature, it glows green. Similarly, when a green glass is heated to high temperature, it glows red. But How does a blue or yellow glass glow when heated? I could not find the answers for this when I browsed.
Science news on Phys.org
What evidence do you have of either of these claims?
Ok, so instead of simply Googling for the answer, how about you apply some logic. Did you read the hint that suggests a relationship between the colour of the glass and the colour it will glow?
In the colour spectrum, what relationship do red and green have to each other?
The room-temperature color of the glass refers to the wavelengths that are reflected. As a consequence, those same wavelengths are only weakly emitted when the glass is heated, while other wavelengths are strongly emitted. As the book explains, a lack of green in an otherwise white spectrum will appear red.
There is also the complication that, as an object is heated, it first glows predominately red, and then when heated further this shifts to a white color. Apparently the book is talking about these higher "white-hot" temperature levels for the glass.
Right. So the question simply boils down to one of complementary colours.
