A (hopefully) original theorem
  • Thread starter SpanishOmelette
  • Tags
    Theorem
In summary: So finally you'll havex=\sin\frac{\pi g}{180}\approx \frac{1}{\sqrt{2}}\left(1+\pi\left(\frac{g-45}{180}\right)-\pi^2\left(\frac{g-45}{180}\right)^2\right)y=\cos\frac{\pi g}{180}\approx \frac{1}{\sqrt{2}}\left(1+\pi\left(\frac{g-45}{180}\right)-\pi^2\left(\frac{g-45}{180}\right)^2\right)
SpanishOmelette
Hello fellow members of PF,
I believe I may have created a theorem for calculating the distance travlled on the 2-dimensional plane when gravity and other forces are ignored. Now, if this has been thought of before, that's not my fault. I have not studied this before.
The theorem is this... the distance traveled along the Y axis is equal to the gradient of travel divided by 90, then multiply the speed(m/s) by the time taken (s) (yes, this is d=vt), and then multiply both those terms together.
Then, to also find the distance traveled along the X axis, take v times t and then subtract from it the distance traveled along Y. Sounds fiddley in sentences. But I have enclosed a whiteboard sketch.
So, is this original? Does it work? Has it been thought of before?
Mahmoud.
g/90 x vt = distance moved in y, where g = gradient , angle.
motion along x = (vt) - (g/90 x vt)
jedishrfu said:
Your problem is that of projectile motion and you can determine if your nethod works by comparing it to how its done in introductory physics:
https://en.m.wikipedia.org/wiki/Projectile_motion
Does your solution when plotted on the xy plane produce a parabolic arc?
The OP is ignoring gravity.
No, it's wrong.
What you've done is to complicate simple trigonometry.
Given a right triangle that sits on the x-axis and the hypotenuse is the distance (d) and [itex]\theta[/itex] is the angle that you're traveling at (where [itex]\theta=0[/itex] is along the x-axis), then the distances x and y are
[tex]x=d\cos\theta[/tex]
[tex]y=d\sin\theta[/tex]
You can also replace d by vt if you wish, since d=vt. Also, [itex]\theta[/itex] is in radians. If you use degrees (g, to use your parameters) instead then you'll have to make the transformation
[tex]\cos\theta = \cos{\frac{\pi g}{180}}[/tex]
[tex]x=vt\cos{\frac{\pi g}{180}}[/tex]
[tex]y=vt\sin{\frac{\pi g}{180}}[/tex]
Now, g/90 may be incorrect, but it's not too bad of an approximation (for values between 0-90 degrees, but if you used more than that then it's way off), but a better approximation (which is just approximating sin(x) and cos(x) at [itex]x=\pi/4[/itex] radians, or 45 degrees) would be
[tex]\sin\frac{\pi g}{180}\approx \frac{1}{\sqrt{2}}\left(1+\pi\left(\frac{g-45}{180}\right)-\pi^2\left(\frac{g-45}{180}\right)^2\right)[/tex]
Related to A (hopefully) original theorem
What is a theorem?
A theorem is a mathematical statement that has been proven to be true using logical reasoning and existing mathematical principles.
How is a theorem different from an axiom?
An axiom is a statement that is assumed to be true without proof, while a theorem is a statement that is proven to be true using logical reasoning and existing mathematical principles.
What makes a theorem "original"?
A theorem is considered original if it is a new and innovative statement that has not been previously proven or discovered by other mathematicians.
How do you prove a theorem?
To prove a theorem, you must use logical reasoning and existing mathematical principles to show that the statement is true for all possible cases.
Why are theorems important in science?
Theorems are important in science because they provide a foundation for understanding and explaining natural phenomena and can be used to make predictions and solve real-world problems.
  • General Discussion
  • Other Physics Topics
