A mass inside a horizontal spring
The discussion revolves around calculating the spring constants k1 and k2 for a mass oscillating on a horizontal spring. Participants debate whether the relationship between the spring constants is k = k1 + k2 or 1/k = 1/k1 + 1/k2, ultimately concluding that k = k1 + k2 is relevant for the force acting on the mass. They emphasize the importance of defining the spring constants clearly, distinguishing between k0 (the full spring constant) and k (the one used for angular frequency). Additional conditions related to the mass's position on the spring are also highlighted as crucial for solving the problem. The conversation concludes with a clarification of the definitions, leading to a better understanding of the concepts involved.
tecnica
We have a spring of length l0 tied to two vertical non moving sticks. We place a mass m at 0,45l0 and let it oscillate. If we measure the period of an oscillation, we can find the angular frequency and calculate k. The question is, how can I calculate k1 and k2, the constants of each one of the pieces on both sides of the mass?
w=sqrt (k/m)
So the thing is, I don't know if k=k1+k2 or 1/k=1/k1+1/k2
Which one do you think is correct and why?
We require students to make attempts, the reason for this is that it helps you better in the long run if we help you think rather than simply provide you with an answer.
I guess it is k=k1+k2, because when you move it Δx, the force acting on it is -(k1+k2)Δx, right?
Each of the parts of the spring give a force proportional to their spring constants so what you have given is the spring constant relevant for computing the angular frequency. But you should stop and think for a moment if this is actually the spring constant k of the full spring.
@Orodruin So the spring constant relevant for computing the angular frequency is the one that obeys k=k1+k2, and the spring constant of the full spring obeys 1/k=1/k1+1/k2, right?
Yes. In order to solve this you will also need to think about an additional condition for the relationship between k1 and k2 (a hint is that it will depend on where the mass was connected onto the spring). I also suggest calling the spring constant of the original spring k0 and the spring constant relevant for the angular frequency k in order not to mix them up.
tecnica,
If you have two identical springs, except that one spring is twice as long as the other, which one exhibits a higher spring constant?
Chet
Likes tecnica
Chestermiller said:
tecnica,
Chet
I'm guessing the shorter one has a higher spring constant.
Could it be l1k1+l2k2=l0k (where this k is the one used for the angular frequency)? l1 is the distance between the left vertical stick and the mass, and l2 is the distance between the mass and the right stick.
It might help if you concentrate on one side, l1 say. How does k1 relate to k?
Likes tecnica
Could it be (l1/l0)k1=k ?
Yes.
Likes tecnica
Yes, but with k0, the spring constant of the full spring, not k, the spring constant appearing in the angular frequency.
Likes tecnica
Glad you caught that - I hadn't checked back with the OP to see exactly what k meant here.
Well, part of the problem was that it was not defined in the OP but the same symbol k was used for both ... I defined it in post #6. :wink:
Likes tecnica
Thank you guys, I understand it all now :woot:
