A particle is moving with a velocity of 60.0 m/s
  • Thread starter Thread starter r-soy
    Particle Velocity
A particle initially moves at a velocity of 60.0 m/s in the positive x direction and uniformly decelerates to zero over a 15.0-second interval. The acceleration can be calculated using the formula a = (final velocity - initial velocity) / time, resulting in an acceleration of -4.0 m/s². The negative sign indicates that the particle is decelerating, which is significant as it shows a change in direction of motion. Properly applying the formula and clearly presenting calculations are emphasized for accuracy. Understanding the implications of acceleration signs is crucial in physics.
r-soy
A particle is moving with a velocity of 60.0 m/s in positive x direction at t= 0 and t = 15.0 s the velcity decreases uniformly to zero . What was the acceleration during this 15.0-s interval ? what is the significance of the sign of your answer ?
my answer is
Vo = 0
a = 60 - 0 / 15 = 4
Hi r-soy! :smile:
You must get into the habit of writing the formula clearly on one line, then filling in the numbers on the next line …
if you'd done that, you wouldn't have got the wrong answer! :redface:
So try again, and start with the full formula. :smile:
